Home > Maintenance & Mods (L322) > ABS ECU, the 3 Amigos & steering angle sensor issue
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi guys, I’ve got an issue related to the 3 Amigos on the dash. When I checked the cause on my icarsoft handheld it told me I had a ABS Ecu fault so I swapped it out for a spare. Put it back on the computer, clears the faults & all ABS faults now gone except the 3 lights, abs, traction & hill decent are still on. Now I check again & I get “steering angle sensor initialisation” so I do the lock to lock on start up with the steering but it did nothing.
Any ideas what I need to do now as that “steering angle sensor initialisation” was not showing before I swapped out the abs ecu. How do I get the lights off?
Regards
Paul
 2004 RR 4.4 V8 Autobiography
Post #533318 6th Nov 2019 2:39pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Yes, you need to initialise the steering angle sensor (it needs doing if the ABS ECU is renewed).
The IIDTool can do this.
Post #533341 6th Nov 2019 6:23pm
PaulM
Ok thank you. Only thing is I don’t have an IID tool. Would a computer from a typical garage be able to do this or does it have to be Land Rover specific? 2004 RR 4.4 V8 Autobiography
Post #534038 13th Nov 2019 10:40am
stu1
Don't know sorry, I used an IIDTool.
Post #534120 13th Nov 2019 6:58pm
Rewmer
You need to get the replacement coded to the car otherwise it will always show the 3 amigos. This can’t be done with IID. You need either T4 or Autologic No7 - 2003 V8 Vogue
Post #534733 18th Nov 2019 8:41pm
Danwilderspin
all comms will do it too... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534767 18th Nov 2019 10:37pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
did mine with iIDtool BT with out issues
Post #534783 19th Nov 2019 12:32am
Rewmer
Steering angle sensor calibration yes, not coding though. It will always show the lights until it’s coded No7 - 2003 V8 Vogue
Post #534798 19th Nov 2019 10:11am
