![]() | Home > In Car Electronics (L322) > NavTool - Carplay, HDMI mirroring, video in etc. 2008 L322 |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Just seen this, thanks, im going to revisit the auxiliary wiring, the mic was fairly easy and I think I’ve figured out a route beneath the back seats to the centre console - we’ll see from there. Completely agree, connect, test, then finalise the connections. It’s a bit fiddly but the Navtool video is quite good. I do seem to have a connector left over but seeing as everything seems to work, I’ll not worry too much about it ![]() |
L_G_D Member Since: 30 Dec 2018 Location: Warsaw Posts: 30 ![]() ![]() ![]() |
My unit after a year stopped working. It displays a black screen all the time but reacts to touch.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3256 ![]() ![]() ![]() |
Is it working on the original screen setup? Have you switched from NavTool to Land Rover on the screen? John
Yeap, everything works except navtool. Navtool is responding, after U press NAV button the screen is black, U can click on the screen, U hear the bleep noise and nothing else.
Looks as if it may have to go back to them. They did replace my original unit which was giving disorted audio from the outset.
It's not like that. I hold the NAV button, the system switches to Navtool but the screen is black. It responds to the touch because you can hear a bleep. But you can't see anything. |
I understand that. Have you contacted NavTool? John
Yes, the told to send it for inspection. |
abalanos Member Since: 12 Oct 2018 Location: Provence Posts: 11 ![]() ![]() |
Hello,
jkmmrs Member Since: 29 Jun 2020 Location: Minnesota Posts: 17 ![]() ![]() ![]() |
On the first question: I have to push the Navigation button each time to activate CarPlay with my NavTool. It’s a wired connection so it gets plugged in when entering the truck and disconnected upon exit. The only item that is retained from previous use is the “AUX” for the sound source. |
To be clear, it’s my iPhone that gets plugged in each time I enter the truck |
Thanks JK.
Related to the second question: my system is not Android (it's Apple CarPlay), but one nice feature of NavTool is that it has both an HDMI and a USB connection. So I have two cables running from the left rear of the truck up to the center console. When pressing the HDMI option, I connect my Roku stick to that cable and can then stream TV (YouTube TV) or movies (Netflix) on the front screen for the passenger to enjoy. When pressing the CarPlay option, I connect my iPhone to the USB/lightning cord for that. The touch screen works for the CarPlay but when using Roku I need to use its remote control, not the touch screen. Since installing it a few months ag, the NavTool has worked flawlessly and really makes my 2007 FFRR seem like a newer vehicle. |
