Home > Technical (L322) > Another fuel burning heater question lol
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
So i now know that my FBH does work... I can hear the fuel pump at the rear clicking, i have only a few times had the cabin nice and toasty.
But one thing i cant work out
This morning it was 10 or 11 degrees. I switch the FH on and it started working.. Fuel pump was clicking and the FBH was firing up and the auto light on the climate was flashing. However after about only 10 mins it decided to turn itself off? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #530368 9th Oct 2019 9:09am
andygts
at a guess I'd say battery voltage was getting low. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #530379 9th Oct 2019 10:11am
AJGalaxy2012
+1
Easily proved, hook a battery charger up, trigger the FBH and see how long it runs then. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #530394 9th Oct 2019 2:10pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Had the same issue and eventually LR gave in and changed the battery, no problems ever since...so agree with other comments..... I need more help than most...sorry !!
Post #530395 9th Oct 2019 2:12pm
dazza1983
Fitted a new battery less than 4 months ago, maybe my short journeys havnt charged her fully..
What kind of drive time would give a full ish charge? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #530405 9th Oct 2019 3:08pm
DrRob
Stick it on charge via the towing socket and see if it stays on longer with a full charge Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530407 9th Oct 2019 3:18pm
dazza1983
Don’t have the equipment bud. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #530414 9th Oct 2019 3:38pm
DrRob
If you have towing electrics then worth getting the right kit to charge that way. So easy. No bonnet opening and very discreet. Best kit I bought apart from my IID Bluetooth Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530425 9th Oct 2019 5:31pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
What kit do I need to charge the battery vie the towing electrics
Post #530483 10th Oct 2019 12:42pm
AJGalaxy2012
Either the 7 pin plug or the 13 pin plug dependent on what you have fitted to your car. Wire the battery charger to the permanent live and the earth and thats it. BMW i3 Electric Car
Post #530484 10th Oct 2019 12:44pm
darrenm
13 pin then
Post #530508 10th Oct 2019 4:21pm
AJGalaxy2012
+ve to pin 9, negative to pin 11 BMW i3 Electric Car
Post #530520 10th Oct 2019 6:38pm
DrRob
Buy an adaptor for the charger of your choice. Ctek is the charger of choice around here Thumbs Up
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
So easy Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530524 10th Oct 2019 7:57pm
AJGalaxy2012
Assuming of course you have a CTEK charger (they are good) and cant be bother to screw two wires into a plug. If you dont have a CTEK charger, you can save ££££ by putting the wires into the plug for the charger you already have. BMW i3 Electric Car
Post #530528 10th Oct 2019 8:36pm
dazza1983
Curious, i was playing around with the car yesterday had the boot open for 40 mins or so, and then periodically through the day checked coolant 4 times ish,
i did a short drive to the shops..
my question is could i have drained the battery to a point where this morning my fbh only ran for like 1 minuite?
i fired it up and the pump at the rear was clicking for maybe 1 min and then just stopped..
this thing still fries my brain Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532407 28th Oct 2019 9:47am
