![]() | Home > Technical (L322) > Another fuel burning heater question lol |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Yes indeed it could! -- what battery did you fit? Current: 2011 FFRR Vogue SE 4.4 TDV8
I have something approaching the same issue -- I suspect battery voltage -- I haven't had chance to look at what the voltage threshold is (or even if it can be found and then altered)
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
They certainly are fickle things, i know it works ok because she always fires up with the engine, but i suspect the threshold for battery volatge is too conservative.
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Taken from the FBH manual.
