Home > Technical (L322) > Another fuel burning heater question lol |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
at a guess I'd say battery voltage was getting low. Current
9th Oct 2019 10:11am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
+1
9th Oct 2019 2:10pm |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 |
Had the same issue and eventually LR gave in and changed the battery, no problems ever since...so agree with other comments..... I need more help than most...sorry !! |
9th Oct 2019 2:12pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Fitted a new battery less than 4 months ago, maybe my short journeys havnt charged her fully..
9th Oct 2019 3:08pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Stick it on charge via the towing socket and see if it stays on longer with a full charge Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Oct 2019 3:18pm |
Don’t have the equipment bud. Regards
9th Oct 2019 3:38pm |
If you have towing electrics then worth getting the right kit to charge that way. So easy. No bonnet opening and very discreet. Best kit I bought apart from my IID Bluetooth Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Oct 2019 5:31pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
What kit do I need to charge the battery vie the towing electrics |
10th Oct 2019 12:42pm |
Either the 7 pin plug or the 13 pin plug dependent on what you have fitted to your car. Wire the battery charger to the permanent live and the earth and thats it. BMW i3 Electric Car
10th Oct 2019 12:44pm |
13 pin then |
10th Oct 2019 4:21pm |
+ve to pin 9, negative to pin 11 BMW i3 Electric Car
10th Oct 2019 6:38pm |
Buy an adaptor for the charger of your choice. Ctek is the charger of choice around here
10th Oct 2019 7:57pm |
Assuming of course you have a CTEK charger (they are good) and cant be bother to screw two wires into a plug. If you dont have a CTEK charger, you can save ££££ by putting the wires into the plug for the charger you already have. BMW i3 Electric Car
10th Oct 2019 8:36pm |
Curious, i was playing around with the car yesterday had the boot open for 40 mins or so, and then periodically through the day checked coolant 4 times ish,
28th Oct 2019 9:47am |
