Home > Technical (L322) > Another fuel burning heater question lol
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Yes indeed it could! -- what battery did you fit? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #532412 28th Oct 2019 10:21am
dazza1983
I fitted a big AGM Varta battery..
Its not very old, i just wonder at what voltage does the car say no to the fbh working?
i wonder if that specific range of not working volatge is quite easy to get to even with a good battery once you have played with the car a little.. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #532414 28th Oct 2019 10:30am
Bushy30
I have something approaching the same issue -- I suspect battery voltage -- I haven't had chance to look at what the voltage threshold is (or even if it can be found and then altered)
Simple solution is to have it on a trickle charger, others may be more time consuming to work out Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #532418 28th Oct 2019 11:45am
dazza1983
They certainly are fickle things, i know it works ok because she always fires up with the engine, but i suspect the threshold for battery volatge is too conservative.
Turned mine on again at 5:30 and worked fine.
So I must have put the battery under the threshold yesterday.
Seems like not a lot can put you under the threshold of weather it turns on or not. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #532480 28th Oct 2019 5:04pm
uzp315
Taken from the FBH manual.
However, I feel quite sceptical about this being true to the working of the FBH, 10.5 seems to low to me. I wouldn't expect a battery with 10.5 volts to be able to start a L322. So I have always wondered if this is incorrect, or maybe I read the manual wrong.
Post #533162 4th Nov 2019 6:15pm
