![]() | Home > Maintenance & Mods (L322) > make sidelights into DRLs |
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 ![]() ![]() ![]() |
total newbie here sorry
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Search is near the top, under the banner, white text on brown background
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
You’ll need a Gap IID Bluetooth. Either someone with a pro version or buy your own and then you have it in the glovebox for fault code reading, clearing, suspension calibration, ECU updates...the list goes on. Worth every penny.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Yep did mine on last RR with IDTool - simples Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
not worth doing , the little lights are hardly visible....change the fogs into drls using a drl switch and led bulbs... ... - .- -.
Stans right, they aren’t DRLs (not bright enough) but I did mine because they look pretty. Geoff |
Set your main beam as your DRL's (they aren't really main beam) at 40% power. Land Rover Addict
Thanks Guys, Looks like I'm buying the IID Tool! FFRR
Super - what setting did you choose to keep the sparkly round LEDs lit on ignition on? FFRR 2010 TDV8 3.6 Vogue Stornoway Grey |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
You need to buy the IID then once your up and running... Go to CCF files, DRL set to "Standard" |
Thanks, Craig, IID tool is next month FFRR
Next job on my list. Also going to add the digital speedo little window at same time |
Yep, me too! anyone got a shot of the dash and how this will look?
Use the Search function |
