Home > Maintenance & Mods (L322) > make sidelights into DRLs |
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 |
total newbie here sorry
10th Sep 2019 7:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7787 |
Search is near the top, under the banner, white text on brown background
10th Sep 2019 8:58pm |
10th Sep 2019 8:59pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
You’ll need a Gap IID Bluetooth. Either someone with a pro version or buy your own and then you have it in the glovebox for fault code reading, clearing, suspension calibration, ECU updates...the list goes on. Worth every penny.
11th Sep 2019 7:23am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3774 |
Yep did mine on last RR with IDTool - simples Geoff |
11th Sep 2019 7:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
not worth doing , the little lights are hardly visible....change the fogs into drls using a drl switch and led bulbs... ... - .- -.
11th Sep 2019 7:53am |
Stans right, they aren’t DRLs (not bright enough) but I did mine because they look pretty. Geoff |
11th Sep 2019 8:33am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Set your main beam as your DRL's (they aren't really main beam) at 40% power. Land Rover Addict
11th Sep 2019 12:14pm |
Thanks Guys, Looks like I'm buying the IID Tool! FFRR
15th Sep 2019 8:42pm |
Super - what setting did you choose to keep the sparkly round LEDs lit on ignition on? FFRR 2010 TDV8 3.6 Vogue Stornoway Grey |
16th Sep 2019 9:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
You need to buy the IID then once your up and running... Go to CCF files, DRL set to "Standard" |
16th Sep 2019 10:32pm |
Thanks, Craig, IID tool is next month FFRR
17th Sep 2019 3:39pm |
Next job on my list. Also going to add the digital speedo little window at same time Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Sep 2019 3:47pm |
Yep, me too! anyone got a shot of the dash and how this will look?
17th Sep 2019 5:32pm |
Use the Search function Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Sep 2019 5:34pm |
