Home > Maintenance & Mods (L322) > make sidelights into DRLs
Hozza12163
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
total newbie here sorry
is there an easy way to make the LED ring lights come on with the ignition so thay act as DRLs?
or to have the sidelights on permanently with the ignition maybe?
without upsetting the canbus warnings
sorry if this has been asked but I can't find a search feature on the forum Shocked
Post #527611 10th Sep 2019 7:48pm
mjdronfield
Search is near the top, under the banner, white text on brown background
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #527620 10th Sep 2019 8:58pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #527621 10th Sep 2019 8:59pm
DrRob
You’ll need a Gap IID Bluetooth. Either someone with a pro version or buy your own and then you have it in the glovebox for fault code reading, clearing, suspension calibration, ECU updates...the list goes on. Worth every penny.
Look in the For Sale section. £405 from Dan Roberts at Duckworths Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #527639 11th Sep 2019 7:23am
supershuttle
Yep did mine on last RR with IDTool - simples Geoff
Post #527642 11th Sep 2019 7:42am
not worth doing , the little lights are hardly visible....change the fogs into drls using a drl switch and led bulbs... ... - .- -.
Post #527646 11th Sep 2019 7:53am
supershuttle
Stans right, they aren’t DRLs (not bright enough) but I did mine because they look pretty. Geoff
Post #527650 11th Sep 2019 8:33am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Set your main beam as your DRL's (they aren't really main beam) at 40% power. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #527681 11th Sep 2019 12:14pm
Hozza12163
Thanks Guys, Looks like I'm buying the IID Tool! FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #528144 15th Sep 2019 8:42pm
Hozza12163
Super - what setting did you choose to keep the sparkly round LEDs lit on ignition on? FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #528280 16th Sep 2019 9:24pm
You need to buy the IID then once your up and running... Go to CCF files, DRL set to "Standard" Thumbs Up
Post #528284 16th Sep 2019 10:32pm
Hozza12163
Thanks, Craig, IID tool is next month FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #528335 17th Sep 2019 3:39pm
DrRob
Next job on my list. Also going to add the digital speedo little window at same time Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528336 17th Sep 2019 3:47pm
Hozza12163
Yep, me too! anyone got a shot of the dash and how this will look?
I have my front DRLs now too!
 FFRR
2010 TDV8 3.6 Vogue
Stornoway Grey
Post #528358 17th Sep 2019 5:32pm
DrRob
Use the Search function Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528359 17th Sep 2019 5:34pm
