Home > General > Transfer box 2004 vogue
marco
Wales 2004 Range Rover Vogue 4.4 V8 Alveston Red
Hi, new to the forum but have been following for a bit now. Am told i need a new transfer box motor for my 2004 vogue, does anyone have any experience/recommendations on where to source the parts from, recon second hand etc as the landrover ones are expensive Big Cry
Post #56224 23rd Mar 2011 4:24pm
dan_uk_1984
Is it just the motor then? Not the whole Transfer box?
Who has diagnosed this? What are the symptoms etc?
D
Post #56228 23rd Mar 2011 4:29pm
marco
its been a long drawn out story, had replacement gearbox, didnt work corrcetly, but repaired under warranty, speed sensor issue, then told there were a number of faults including wiring from gearbox to ecu possibly corroded then the transfer box neutral warning coming on and the box not changing up and down correctly then the transfail safe prog warning coming on. The dealer who supplied the box, said the transferbox motor was faulty as well as the wiring and this was affecting the performance of the gearbox wheras the guys who fitted it have checked wiring and say its fine and then swapped the transferbox from another car to mine and drove it without fault for half an hour theyre recommending a replacement transferbox from landrover , normally the faults appear within about 5-7 mins of driving, so just trying to understand the options before I shell out the money. Confused
Post #56304 23rd Mar 2011 8:06pm
dan_uk_1984
They definatelu said the transfer box motor? Not the Module.
The Motor is the bit that changes from Hi to Lo. These can seize if Hi/Lo isn't used every once in a while. The Module on the other hand can crap out whenever it feels like it. Are they trying to get you to buy a whole new transfer box?
How much are they quoting?
D
Post #56312 23rd Mar 2011 8:19pm
marco
£730 plus vat, which i presume is the module rather than just the motor
mark
Post #56320 23rd Mar 2011 8:46pm
dan_uk_1984
That sounds crazy for the module!
Might be worth dropping RRPhil an e-mail on RangeRovers.net.
D
Post #56324 23rd Mar 2011 9:22pm
marco
Thanks, appreciate your help
Post #56330 23rd Mar 2011 9:57pm
