![]() | Home > General > Transfer box 2004 vogue |
Is it just the motor then? Not the whole Transfer box?
marco Member Since: 23 Mar 2011 Location: Holywell Posts: 4 ![]() ![]() ![]() |
its been a long drawn out story, had replacement gearbox, didnt work corrcetly, but repaired under warranty, speed sensor issue, then told there were a number of faults including wiring from gearbox to ecu possibly corroded then the transfer box neutral warning coming on and the box not changing up and down correctly then the transfail safe prog warning coming on. The dealer who supplied the box, said the transferbox motor was faulty as well as the wiring and this was affecting the performance of the gearbox wheras the guys who fitted it have checked wiring and say its fine and then swapped the transferbox from another car to mine and drove it without fault for half an hour theyre recommending a replacement transferbox from landrover , normally the faults appear within about 5-7 mins of driving, so just trying to understand the options before I shell out the money. |
They definatelu said the transfer box motor? Not the Module.
£730 plus vat, which i presume is the module rather than just the motor
That sounds crazy for the module!
Thanks, appreciate your help |
