Home > Technical (L322) > Rear Shock and oil leak |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Ok, so read some threads here and understand the steps.
24th Aug 2019 7:56pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Yours (if an 09 facelift) has Adaptive Dynamics i.e. continuously variable suspension tuning
24th Aug 2019 8:11pm |
Ah.. so its likely to have connection at the top of the mount therefore I would need to replace like for like..
24th Aug 2019 8:24pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1745 |
From memory, it's a simple job. Nothing difficult at all |
24th Aug 2019 9:43pm |
Cheers Mikey.. gonna order it and then have a wee go at it.. will report back Current:
25th Aug 2019 7:41am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2635 |
3 bolts at the top, flip up back seats , find the 3 bolts just behind the back doors, quite a quick job tbh.
25th Aug 2019 1:26pm |
Mr Tee, I had seen the thread you pasted above but couldn't work out how to access the 3 bolts at the top..
27th Aug 2019 6:57pm |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 |
I’ve just had to do mine - CVT type for adaptive dynamics. The oil reservoir dropped off one and within a few miles, all the oil was gone leaving lots of bounce and noise.
28th Aug 2019 5:02pm |
Thanks Mightymarco.. this is reassuring..
28th Aug 2019 7:23pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
does the big bolt in the bottom end come out ok or is it typically siezed? |
29th Aug 2019 9:01am |
