![]() | Home > Technical (L322) > Rear Shock and oil leak |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Ok, so read some threads here and understand the steps.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Yours (if an 09 facelift) has Adaptive Dynamics i.e. continuously variable suspension tuning
Ah.. so its likely to have connection at the top of the mount therefore I would need to replace like for like..
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1803 ![]() ![]() |
From memory, it's a simple job. Nothing difficult at all |
Cheers Mikey.. gonna order it and then have a wee go at it.. will report back Current:
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
3 bolts at the top, flip up back seats , find the 3 bolts just behind the back doors, quite a quick job tbh.
Mr Tee, I had seen the thread you pasted above but couldn't work out how to access the 3 bolts at the top..
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 ![]() ![]() |
I’ve just had to do mine - CVT type for adaptive dynamics. The oil reservoir dropped off one and within a few miles, all the oil was gone leaving lots of bounce and noise.
Thanks Mightymarco.. this is reassuring..
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
does the big bolt in the bottom end come out ok or is it typically siezed? |
