Home > Technical (L322) > Nice lighting feature? |
Worth remembering that the LCM stores a copy of the Mileage data - if you swap to an LCM from a different car you will get a "tamper" warning on the dash.
24th Mar 2011 8:47am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Eh? I have it on my 02 Vogue. Switch the engine off with headlight switched on, rotate headlight switch to off and lights come back on for 40 seconds. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
24th Mar 2011 1:40pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3138 |
@ Mattstevenson: pre 05 models DO have the auto lights as my 2002 HSE has it (just found out by accident!) as well as rain sensitive wipers. Also have a few Vogue features (rearheated seats) but no stanav. |
25th Mar 2011 11:31pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
im off outside to try it now "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back " |
26th Mar 2011 12:58am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Are you sure? do you have 4 positions on the light switch e.g off, side lights, dim beam, auto lights. And do they work. If so someone has upgraded you car with auto lights as they were NOT available before the 05 upgrade. Even the top of the range 02 vogue spec did not come with auto lights nor was it a factory option, so a previous owner must have replaced the light switch, sensor and lcm ecu to the post 05 versions. All l322 range rovers have the rain sensitive wipers. Matt |
26th Mar 2011 8:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
is that when i tell you where to go.... ... - .- -. Y. O. L. O. . |
26th Mar 2011 9:51am |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
You can also enable the headlight delay manually via:- Get in the car, lock the doors, then hold the LR button on the keyfob whilst holding the headlights on flash. Then , after a few seconds, the words 'headlight delay' will appear on the LCD display at which point release the headlight stalk. The delay is now enabled, but is manual in that once you've removed the key, you have to 'flash' the headlights via the stalk to trigger them. One thing I haven't tried is putting the lights on the auto setting (I never use it) to see if this makes any difference (i.e. might put them on for you when engine is turned off, I'll have to try it). Steve Main car : FFRR L405 Vogue SDV8 Other car : Vauxhall Lotus Carlton Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans |
29th Mar 2011 11:34pm |
