Home > Maintenance & Mods (L322) > 2011 TDV8 4.4 Diesel rear dampers. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2531 |
Keep the undamaged one as a spare for either side as the top bracket can be removed to allow the shock to be fitted to the other side. |
27th Jul 2019 9:21pm |
Plim66 Member Since: 27 Dec 2017 Location: North Yorkshire Posts: 17 |
Thanks that's good advice. 😁 |
28th Jul 2019 3:51pm |
Tomo676 Member Since: 07 Aug 2018 Location: Aberdare, South Wales. Posts: 51 |
I had exactly the same problem with my damper on at3.6 tdv8, 2010. Got a pair of bilstein's off the bay for £550. |
29th Jul 2019 2:11pm |
Cheers I think mine had rusted out and split the joint. You did well with that price! |
29th Jul 2019 8:09pm |
RickR Member Since: 16 Aug 2018 Location: Scunthorpe Posts: 8 |
Afternoon all, ive just ordered a pair of rear shocks for my 2010 Fatty from Duckworths @ Market Rasen. £440 inc vat for the electronic gizmo Bilsteins. I`d best start squirting all the nuts n bolts ready! |
30th Jul 2019 4:05pm |
A very good price well done. Good luck with the fitting |
30th Jul 2019 10:56pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
what symptoms are felt when the rear dampers are worn (apart from leaking oil etc!) |
20th Sep 2019 10:08am |
Hi sorry for the delay in replying, the first symptoms I felt rather than saw were a feeling that the rear end was much more lively and bouncy than normal. It wallowed in corners and just felt "different". On inspection I saw that one of the reservoirs had completely detached from the shock body and all the oil had gone West. Oil leaking down the damper body is a sign that all is not well.
21st Sep 2019 6:15pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 |
If you've ever had a classic RR and disconnect the dampers, then that is exactly the effect you get. The rear axle 'tramps and bounces and feels like the back end is sliding. Mine went last week and replaced them.
22nd Sep 2019 1:39pm |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
I agree with the symptome above. For me, I noticed that the car was pitching more on uneven roads. I got my local Indy to do the work. He also replaced the top rear suspension bushes and cleaned and lubricated the handbrake for a total cost of £880, including 3 hrs labour. the car handles so much better now. 2011 Vogue TDV8 4.4
22nd Sep 2019 2:16pm |
I was asking what the symptons of worn dampers were because my 2010 is feeling "funny " at the rear.
22nd Sep 2019 7:59pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Mine seems to roll much more than I would expect and I'm wondering if this is down the rear dampers being past their best. They don't appear to be leaking though.
23rd Sep 2019 8:18am |
