Home > Maintenance & Mods (L322) > 2011 TDV8 4.4 Diesel rear dampers.
Plim66
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
I have just replaced the rear dampers on our Vogue, they were the expensive active ones and set me back £550
However this was better than the list price of £350 each! Because I found the job was quite straightforward I thought it was worth sharing how it went.
I chocked the wheels, cracked the wheel nuts, jacked it up, secured it on axle stand, removed the wheel and used a trolley jack to support the wheel hub and just to remove the tension on the damper bolts.
I removed the bottom through bolt which came out very easily. The damper bush slots into the end of the bolt tube and this is what takes the load off the bolt, arrows indicate the bush and where it came out.
Back inside with spare wheel cover removed you can just see the top mounting nuts. Going around into the passenger seat with the seat folded forward and the carpet pulled up I got perfect access. Our dog cage got in the way slightly. With these undone and the wire carefully unplugged the damper fell out.
The cause of the problem is obvious, the expansion cylinder at the bottom had dropped off.
Replacing with the new one was the reverse order. Note I put the top in first with the thin felt gasket swapped across, reconnected plug into socket. Damper only fits one way and they are handed. Then I did the bottom through bolt remembering to slot the bush back into the tube end correctly. I torqued the top nuts to 63nm /46-lb-ft and did the bottom one finger tight initially. I refitted the wheel and lowered the car to the ground and then torqued up the bottom nut to 90 nm 66-lb-ft. The idea of this was to let the bush find it's settling place before tightening. I should have used fresh nuts and bolts but they were all in very good condition and so a little thread lock was applied instead. Obviously carpets refitted and so on. One side at a time for safety and I didn't let the hubs dangle on the air bags to avoid over stretching them. It is a big heavy thing so proper lifting and supporting kit required !!!
Time about two hours with the phaffing with jacks and so on.
Obviously don't attempt this unless you are completely confident in what you are doing and have the proper equipment to use. This post was only documenting my experience not a workshop guide.
The ride was transformed!
Post #522973 27th Jul 2019 1:31pm
GraemeS
Keep the undamaged one as a spare for either side as the top bracket can be removed to allow the shock to be fitted to the other side.
Post #523028 27th Jul 2019 9:21pm
Plim66
Thanks that's good advice. 😁
Post #523084 28th Jul 2019 3:51pm
Tomo676
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I had exactly the same problem with my damper on at3.6 tdv8, 2010. Got a pair of bilstein's off the bay for £550.
Post #523190 29th Jul 2019 2:11pm
Plim66
Cheers I think mine had rusted out and split the joint. You did well with that price!
Post #523239 29th Jul 2019 8:09pm
RickR
England 2010 Range Rover Vogue TDV8 Galway Green
Afternoon all, ive just ordered a pair of rear shocks for my 2010 Fatty from Duckworths @ Market Rasen. £440 inc vat for the electronic gizmo Bilsteins. I`d best start squirting all the nuts n bolts ready!
Post #523331 30th Jul 2019 4:05pm
Plim66
A very good price well done. Good luck with the fitting
Post #523376 30th Jul 2019 10:56pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
what symptoms are felt when the rear dampers are worn (apart from leaking oil etc!)
Post #528611 20th Sep 2019 10:08am
Plim66
Hi sorry for the delay in replying, the first symptoms I felt rather than saw were a feeling that the rear end was much more lively and bouncy than normal. It wallowed in corners and just felt "different". On inspection I saw that one of the reservoirs had completely detached from the shock body and all the oil had gone West. Oil leaking down the damper body is a sign that all is not well.
All the best
Andy
Post #528735 21st Sep 2019 6:15pm
Big Boy R44ROV
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
If you've ever had a classic RR and disconnect the dampers, then that is exactly the effect you get. The rear axle 'tramps and bounces and feels like the back end is sliding. Mine went last week and replaced them.
Ride is transformed and is just flat again on corners.
it is an easy job to do.
Great write up Thumbs Up Tony
You're always in the Censored ........it's just the depth that varies
2011 5.0 Autobiography Fuji White
2019 Audi Q2 in White
04 SL55AMG
Gone:
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
V8 Lightweight
Too many series to mention !
IID for L322
Post #528766 22nd Sep 2019 1:39pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
I agree with the symptome above. For me, I noticed that the car was pitching more on uneven roads. I got my local Indy to do the work. He also replaced the top rear suspension bushes and cleaned and lubricated the handbrake for a total cost of £880, including 3 hrs labour. the car handles so much better now. 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #528767 22nd Sep 2019 2:16pm
dexion7
I was asking what the symptons of worn dampers were because my 2010 is feeling "funny " at the rear.
The rear of the car feels "solid" as though the only resilience is the tyres and the rear left has a distinct thump when there's a pothole.
Suspected a damper (or 2) as both are slightly misting up so took them off this morning but both seem ok.
Discovered that (both sides) the lower wishbone, INNER , rear bushes are worrn out (the mot guy did say they were worn) as the steel insert has parted company with the rubber.
However, the thump is heavier than that would give and I think its down to the forward bush on the rear subframe (left side).
The rubber is sticking out of the top of the tube so that the steel parts are touching at the bottom of the tube and it looks quite different to the other side. I also had a sneeky peek at another FF which parks up a mile away and that one makes all of my subframe bushes looking a bit tired.
So, its new subframe bushes and 2 new lower wishbones to fit! Shocked
Post #528800 22nd Sep 2019 7:59pm
kooky_guy
Mine seems to roll much more than I would expect and I'm wondering if this is down the rear dampers being past their best. They don't appear to be leaking though.
My wife really doesn't like the ride and it's certainly much worse then her X-Trail in this respect.
Does that sound like the rear dampers to you guys? Its on 120k. 2010 4.4 TDV8 Vogue SE
Post #528826 23rd Sep 2019 8:18am
