![]() | Home > Maintenance & Mods (L322) > Double sided tape for bonnet lettering. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
New letter aren't expensive if bought from the likes of powerful uk, etc and you get template etc to make job easier. 2015 4.4 AB
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
I would say that the lettering template is invaluable. If I didn't have one, I'd probably buy a new set of letters which come with adhesive on the back as well as the letter spacing template.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
The 3M tape is good stuff (as long as you prep things right, which I am sure you will !)
Thanks gents. |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
You can get 5mm wide 3M tape here;
So you can, ordered a roll to see what it's like. My only reservation about buying on eBay is whether or not the product is genuine or a copy.
I bought the 7mm wide stuff from them and it seems ok. Current: FF Westminster money pit
The tape arrived yesterday and did the job beautifully. I can only conclude the tape the trim came with from Powerful UK is cheap rubbish as this genuine 3m stuff is really good. Current: FF Westminster money pit
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Where can i find front lettering template?
Why not buy new badges and have them painted before installing them? |
They have no problem
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I always use adhesion promoter (3M Primer 94) with double sided tape or vinyl wrap. it greatly increases bond strength. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8697 ![]() ![]() ![]() |
New silver letters went into my 3.6 with a template. Can vouch for proper 3m tape tho, stick Go Pros to my ski hat with it and they never come off....even after big Crashes. There is nothing that can't be fixed with a hammer😜😜
The problem about tapes are their thickness.
