Home > Maintenance & Mods (L322) > Battery query
j_rov
Battery query
Hi, anyone on here know why the MY10 3.6 needs an AGM battery? It’s coming up that on various factors lookup tools.
Thanks __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #514433 6th May 2019 10:19am
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
Not sure the reason why but I have just replace my my 11 battery the original was agm so replaced with agm.
At a guess I would say because of the amount of electronics on the car. DVD etc. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #514435 6th May 2019 10:56am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
using the search function you will find lots of threads about this.
Post #514443 6th May 2019 12:11pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
The facelift models have the AGM battery. It also has different software that controls the charging circuit as AGM batteries are charged using a different cycle to a standard lead acid battery. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #514444 6th May 2019 12:23pm
j_rov
Thanks all. __
Land Rover History:
1976 Series 3 2.25
Post #514491 6th May 2019 9:03pm
Bingo_123
spot on, thats true, so go for AGM battery. My 10 plate also has AGM battery.
Post #514521 7th May 2019 10:37am
Andy
I've got a standard battery on my 59 plate (10MY) it was on when we bought it. Should i change to AGM? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514576 7th May 2019 4:45pm
Witzend
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Main dealer changed mine (2008 TDV8) and put AGM on. A true friend is someone who worries about letting you down........ But never does.
Post #514581 7th May 2019 5:33pm
