Home > Maintenance & Mods (L322) > Battery query |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Not sure the reason why but I have just replace my my 11 battery the original was agm so replaced with agm.
6th May 2019 9:56am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
using the search function you will find lots of threads about this. |
6th May 2019 11:11am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
The facelift models have the AGM battery. It also has different software that controls the charging circuit as AGM batteries are charged using a different cycle to a standard lead acid battery. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
6th May 2019 11:23am |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 |
Thanks all. __
6th May 2019 8:03pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
spot on, thats true, so go for AGM battery. My 10 plate also has AGM battery. |
7th May 2019 9:37am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I've got a standard battery on my 59 plate (10MY) it was on when we bought it. Should i change to AGM? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
7th May 2019 3:45pm |
Witzend Member Since: 12 Nov 2018 Location: Barnsley Posts: 17 |
Main dealer changed mine (2008 TDV8) and put AGM on. A true friend is someone who worries about letting you down........ But never does. |
7th May 2019 4:33pm |
