Home > Maintenance & Mods (L322) > 4.4 TDV8 Starter culprit
GraemeS
Australia
Also swap the positions of the studs if their lengths are the same. Due to the direction of the current flow and hence the arcing, 1 will burn much worse than the other.
Post #514036 2nd May 2019 9:19pm
GraemeS
Australia
Baltic Blue wrote:
PF-GF57
This only identifies the plastic compound.
The repair kit for the TD5's starter includes studs although at least the heads look smaller and I think the bolt size too.
Post #514038 2nd May 2019 9:27pm
mpirie
I have a feeling that the studs are of different lengths and will confirm once I pull the starter apart again for your measurements Graeme.
Mike
Post #514072 3rd May 2019 9:06am
Baltic Blue
Sorry Graeme/Mike ,
I didn’t see the request for stud measurements until later, after I had rebuilt it, but like Mike I think the one under the main copper bar feed is shorter. The nut size is 17 mm.
PS. A note of caution.
The wire connector to the coil broke away from the crimp as I pulled it apart, so I had to do a repair by soldering a bit of the earth wire from a scrap piece of 1.5mm twin & cable I had lying around.
Post #514078 3rd May 2019 9:20am
GraemeS
Australia
I think it would be safe enough to bank on just cleaning-up the bolt heads and plate when the starter fails rather than needing to have new bolts on hand, although if I had new bolts then I'd certainly fit them.
Post #514080 3rd May 2019 9:50am
mpirie
Re: 4.4 TDV8 Starter culprit
GraemeS wrote:
Could you ascertain and advise the stud's shank dia and length please? eg standard M8 x 30mm. The head dia would also be useful.
Here you go Graeme:
Post #514372 5th May 2019 3:13pm
Baltic Blue
Brilliant photos Mike 👍
One contact in mine was worn completely smooth, but as can be seen in my picture , polished up OK with no ridges, but I am not sure if that would make any difference?
I have been looking for any product that would reduce contact burn, silicone grease or similar, but not found anything.
Post #514374 5th May 2019 4:30pm
GGDR
Great stuff guys!
Mike have you refitted the old one then?
. Cheers, Greg
Post #514376 5th May 2019 5:21pm
GraemeS
Australia
Thanks Mike for the pictures showing the dimensions. My son-in-law works for a company that produces starter motors amongst other components so I'll see if he can help.
Post #514404 5th May 2019 10:10pm
mpirie
gonna_go_double_r wrote:
Great stuff guys!
No, I had to keep the car on the road (otherwise i'd have to drive the wife''s Focus.......oh, the indignity Big Cry ) so fitted the new one instead.
But, that's part of the reason for the thread......if anyone finds themselves with a non-starting starter, and are not desperate to get the car back on the road, they can (for a bit of time and effort) save themselves £260+
Mike
Post #514413 6th May 2019 6:48am
mpirie
It'll be interesting to see if they make components for other starters that use the same dimensions.
Mike
Post #514414 6th May 2019 6:50am
