Home > Maintenance & Mods (L322) > 4.4 TDV8 Starter culprit |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 |
This only identifies the plastic compound. The repair kit for the TD5's starter includes studs although at least the heads look smaller and I think the bolt size too. |
2nd May 2019 8:27pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 |
I have a feeling that the studs are of different lengths and will confirm once I pull the starter apart again for your measurements Graeme. Mike |
3rd May 2019 8:06am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
Sorry Graeme/Mike ,
3rd May 2019 8:20am |
I think it would be safe enough to bank on just cleaning-up the bolt heads and plate when the starter fails rather than needing to have new bolts on hand, although if I had new bolts then I'd certainly fit them. |
3rd May 2019 8:50am |
Here you go Graeme: |
5th May 2019 2:13pm |
Brilliant photos Mike 👍
5th May 2019 3:30pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Great stuff guys!
5th May 2019 4:21pm |
Thanks Mike for the pictures showing the dimensions. My son-in-law works for a company that produces starter motors amongst other components so I'll see if he can help. |
5th May 2019 9:10pm |
No, I had to keep the car on the road (otherwise i'd have to drive the wife''s Focus.......oh, the indignity ) so fitted the new one instead. But, that's part of the reason for the thread......if anyone finds themselves with a non-starting starter, and are not desperate to get the car back on the road, they can (for a bit of time and effort) save themselves £260+ Mike |
6th May 2019 5:48am |
It'll be interesting to see if they make components for other starters that use the same dimensions. Mike |
6th May 2019 5:50am |
