![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Starter culprit |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Do you think it would be possible to clean the contact up and then add metal by brazing and then filing to size. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 ![]() ![]() ![]() |
Mike,
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
I don't think it needs additional copper added to the contacts, just a chemical clean. The studs themselves are solid, it's just the build up of carbon that was stopping a good contact from happening. A soak in brake cleaner would probably be enough to remove the carbon. Mike PS. I'm no ecomentalist (who could be driving an FF) but considering how much it cost to buy a new starter......all for the sake of removal, dismantling, cleaning and reassembly. If i'd known it would be such a simple repair, I wouldn't have bought a replacement! |
Mike,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 ![]() ![]() ![]() |
The contacts could be mechanically cleaned (filed/ground) but the remaining material thickness will indicate whether the contacts will last long enough to warrant the work. I doubt that brazing would be appropriate as the other metals in brass will have different electrical and physical properties.
This site http://www.hummerknowledgebase.com/electric/cssc.html provides instructions for cleaning-up contacts, stating that the copper contacts should be cleaned to a shiny condition and suggest that the plate be cleaned with a wire brush, possibly using a dremel. |
Better still, silver plate the contacts and stop the arcing altogether. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Maybe he was looking at it with "commercial" eyes inasmuch as it would not be worth it for him because of the slim margins to be made? The difference between him and us is that most of us would do the work for fun since they are our own cars. Mike |
I agree Mike.
The copper stud contact looks easy enough to have manufactured. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Mike, Could you ascertain and advise the stud's shank dia and length please? eg standard M8 x 30mm. The head dia would also be useful. |
It’s raining, so....
