Home > Technical (L322) > L322 2011 4.4 TDV8 Suspension / compressor fault |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
You are in luck (sort of) my post 'suspension issues after towing' describes the exact symptoms you have
18th Apr 2019 8:25am |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 |
Thanks, but my compressor gets up to pressure & cuts out as required, it doesn’t kick in again, therefore I’m under the understanding that the pressure is fine.
18th Apr 2019 8:52am |
Exhaust on the compressor not opening to allow it to start up again? Assuming it works like an unloading valve on a static compressor
18th Apr 2019 9:04am |
Do you know the pressure is fine - I. E have you checked on diagnostics? |
18th Apr 2019 9:05am |
I don’t have a IID tool, hoping my sons mate will call over Easter and connect his up.
18th Apr 2019 9:15am |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
Had the same sort of issue, there is a little screw in brass exhaust filter/silencer on the compressor that gets clogged, you can replace it , or do as i did , unscrew and throw away to replace at a later date (that was 2 years ago) , you will get a louder PSSSHHHH when the compressor exhausts but apart from that all good ! |
18th Apr 2019 9:18am |
Thanks, but that is brand new along with the compressor. Current: 2015 4.4 SDV8 Autobiography
18th Apr 2019 9:30am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
Might be worth looking at the plastic pipes and the big tubular reservoir on the drivers side to check for leaks, could even be that the bags are still fine, but the system from them back is leaking somewhere?
18th Apr 2019 9:40am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1185 |
Did you replace the compressor with the same make? if not I believe it needs to be programmed? |
18th Apr 2019 2:08pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
I got a valve block if you need one - the one closest to the compressor (i.e. IN the boot) Land Rover Addict
18th Apr 2019 2:29pm |
Compressor changed like for like. Current: 2015 4.4 SDV8 Autobiography
19th Apr 2019 5:58pm |
UPDATE:
22nd Apr 2019 6:01pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Might need the exhaust valve brass filter thingy bored out with a drill. Common issue.
22nd Apr 2019 6:07pm |
22nd Apr 2019 6:13pm |
