![]() | Home > Technical (L322) > Gearbox service 2011 4.4tdv8 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
not sure but I did three complete changes just from the sump drain with a day or a long drive between. That way you have full fluid change. Changed the sump (filter) after the second one.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
3 drain and refills is not a full fluid change... |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 184 ![]() ![]() ![]() |
Where abouts are you |
Fair enough Mikey |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Do yourself a favour and drive to Dundee and let Mikey at MMP do it for you.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
Just googled 'Shetland to Dundee'..................14hrs |
Graham Nic Member Since: 11 Mar 2020 Location: Lerwick, Shetland Posts: 16 ![]() ![]() |
The Shetland Isles |
Thanks, I might be coming down to the mainland this year, any idea how much they charge for a gearbox flush/service? |
Tell me about it? 14 hours on the ferry just to get to Aberdeen! Don't mind tackling it myself, but as I said in the original post, does anyone know which pipe is the return from the cooler, top or bottom and is this the easiest/best way to do a self flush? Also what kit is the best? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
PM Mikey and ask him. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
