Home > Technical (L322) > engine swap |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
I put a replacement 2004 X5 engine into my FF last year, just needed the sump changing over. Whether the X5 and 540 engines are the same block and interchangable, is probably a question for a BMW forum. David
4th Apr 2019 1:58am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have a couple of M62TUB35 engines to play with and one is out of a 535. You will need to check the right hand engine mount looking from the front as the X5 will use the same larger longer engine mount where the 540 might be shorter, if you have a photo I can tell you. Sump for sure as already mentioned and I think oil pump.
4th Apr 2019 2:46am |
robo Member Since: 09 Mar 2012 Location: solihull uk Posts: 36 |
Many thanks for replies,so maybe better to source an x5 engine as dont want to be swapping heads etc over |
4th Apr 2019 7:52am |
GI JIM Member Since: 23 Jan 2012 Location: Scotland Posts: 41 |
This is not an add so I apologise if anyone may think otherwise.
4th Apr 2019 12:17pm |
have emailed you Jim,thank you |
5th Apr 2019 5:49pm |
