![]() | Home > Technical (L322) > Engine don't start now |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Do a full battery reset if only to eliminate it. It'll nothing. Details of dis-connection procedure is in wiki. Just touch the Pos + & neg- leads together before reconnecting the battery and its done |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35663 ![]() ![]() |
i'm still scratching my head trying to figure why disconnecting the seat power has stopped your FF from starting.. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
You need diagnostics , my 04 will lose the immobiliser code and will crank but not start if I disconnect battery, not saying it’s that but rangey diagnostics will most likely tell you. |
Cheapscaff Member Since: 04 Mar 2019 Location: Uxbridge Posts: 31 ![]() ![]() ![]() |
Hi holidaychicken thanks for your support I have a icarsoft reader and it says imobilizer lost contact with key they are limited to what they can reset and can't clear it.
Lock and unlock the vehicle with the key - then try. Land Rover Addict
have you tried your spare key?? |
Yes tried the spare key. The garage weren't to helpfull I was hoping for a mobile fix instead I got transport it to us and we will get a mobile to look at it. Not willing to give out any contact numbers. Like I already said my carsoft reader says key lost contact with immobilizer that can't be to hard to put right can it?? |
Worth a try ....
Initialisation Procedure
Also this (which is similar) : https://www.rswsolutions.com/index.php/mki...-procedure Land Rover Addict
Hi dmrr thanks for your support. I have just tried that and the engine Is still dead. I now seem to be able to program only one key when I do the second key the 1st one don't work by not work I mean unlocking doors. I done some checks yesterday and the fuel pump relay is not energising and I have no spark on the plugs. I have attached picture of what my reader says.
Do both keys within 30 seconds - I think maybe that DTC is a dud.... Land Rover Addict
Sorry, just Googled the DTC - a lot of advice available..... Land Rover Addict
I would say your EWS3D immobiliser has lost its pairing with the Bosch engine management ECU, something that my 04 4.4 does too regularly.
