Home > Technical (L322) > Engine don't start now
Page 3 of 4 <1234>
holidaychicken
after a quick google of P1672 L322
https://www.aulro.com/afvb/freelander-1-a/...p1672.html
Post #510947 5th Apr 2019 6:26am
Cheapscaff
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi holiday Thanks for that link I do you think this is a main dealer fix only then. I did look up fault code attached.
Post #510951 5th Apr 2019 7:28am
Cheapscaff
I have a Land Rover independent coming next week to re sync. I'll post the results Bow down
Post #511030 5th Apr 2019 3:45pm
holidaychicken
Duplicated post removed - I blame Navy Strength Gin
Post #511085 6th Apr 2019 12:30am
holidaychicken
I took mine on a trailer to the dealer which was expensive but the next two times they came out to me with a testbook laptop and it takes about 3 minutes. I have since bought a faultmate.
Check if the GAP IID will do it as a dealer visit still used to cost me £100.
Good luck
Post #511086 6th Apr 2019 12:32am
Cheapscaff
Hi holiday I'm hoping this gets sorted next week I also have a disco 3 an rrs and have no problems with any of them you say yours has been done 3 times that's worrying I've had this l322 a month an not got it on the road yet. I might look in to the faultmate unit. I have a isoftcar reader for service lights ect bit of a chocolate teapot really no use at all for anything else. Rolling with laughter
Post #511114 6th Apr 2019 10:19am
holidaychicken
Mine has done it quite a few times but only after disconnecting the battery or trying to start with a very flat battery. I suspect it has a faulty EWS immobiliser that loses the code when power is disconnected, that or the engine ECU. Hopefully yours is the same fault and easily rectified with the reprogram. It was quite rare when mine did it first 5 or so years ago and I could only find a few references worldwide including the X5 forums but it seems to be more common now. I wish I had the time to really find out why but since I managed to pick up the faultmate at a reasonable price I just reprogram it.
Strange thing is it doesn’t do it every time now.
I can’t even lend anyone the faultmate as it’s vin locked which is understandable.
Good luck, let us know how it goes.
Post #511185 7th Apr 2019 6:25am
Cheapscaff
All done in 5 minutes running nicely now. BUT I do have this thing with the steering column making a hissing noise and going up or down when I turn the ignition on/off off-sometimes. Can I turn the auto function off or do I need special equipment. Tai
Post #511834 12th Apr 2019 3:02pm
Cheapscaff
Or do I need to start a new thread.
Post #511840 12th Apr 2019 3:19pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
mine dose that all the time, i thought it was normal RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #511845 12th Apr 2019 3:36pm
Cheapscaff
When I say down I mean it nearly cuts my legs off at the knees Rolling with laughter
Post #511847 12th Apr 2019 3:39pm
holidaychicken
You should be able to link the position to your individual key but it will adjust each time you get in using that key unless you set the position to right at the top which is where mine returns to when ignition switched off.
i think it isi set by the buttons on the drivers seat panel, check the manual.
The steering column adjust is another common failure along with everything inside and outside of the car..
Post #511850 12th Apr 2019 4:40pm
Cheapscaff
Hi holiday thanks for your support. I will try that and reset it at the top I would rather is just stayed still.
in my rrs the easy entry/exit can be turned off on the stalk.
Post #511851 12th Apr 2019 4:48pm
holidaychicken
The steering ECU is tied in with your immobiliser ECU that you have just reprogrammed ....
Post #511901 13th Apr 2019 12:37am
Cheapscaff
Hi all steering now sorted. Bow down the next issue I have is the fuel pump is now running continually sounds quite loud from outside I did have the old one out and broke the hose connection on the top so I bought a replacement on the bay which had a pump in it which worked so I put it in. Now could it be a faulty valve in the pump which is not holding pressure or another issue any ideas on testing it.
Post #511940 13th Apr 2019 12:56pm
Page 3 of 4 <1234>
