Home > Off Topic - Other Cars > Cabriolet roof faded |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7948 |
I used some stuff by Renovo on my Mini - seemed to do the trick
30th Mar 2019 4:46pm |
iani Member Since: 27 Oct 2012 Location: Corby UK Posts: 37 |
Another vote here for renovo, just make sure you are thorough on the cleaning stage. When you use the Renovo make sure you wipe runs off paintwork quickly, can be a bit of a pain once it has dried. 4.2SC; 1960 TR6; XF Sportbrake
30th Mar 2019 6:12pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I had a Mini that needed doing and used some Milton sterilising tablets with a brush to agitate the dirt |
30th Mar 2019 9:22pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
What car? What type of roof MrBlonde?
30th Mar 2019 11:07pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Cheers all
31st Mar 2019 2:24am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
+1 for the renovo but only the staining and water proving stages. I found renovo cleaner a waste of time. SWMBO 6 series had a lot of algae which had baked hard. Only a decent citrus cleaner could cope with that and it took several attempts. I resorted to soaking it in citrus cleaner and covering with cling film. left if for a couple of hours then jet washed hard. it did the trick.
31st Mar 2019 9:34am |
In that case, the renovo should work fine sir |
31st Mar 2019 2:54pm |
Cheers all
1st Apr 2019 10:39am |
