Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
Guys, have you read this thread? It ‘ends’ with a solution on running a parallel cable for the triggering wire… which has an inherent high resistance, that doesn’t seem to have ever been found, but fixed by running the second parallel cable from fuse box to starter motor. I had the issue, (like many) and changed starter but it remained… ran the paralllel cable and had no issues at all since. Here. (takes about 1/2 hour, and a £5 small reel of cable from Halfords) https://www.fullfatrr.com/forum/topic31909-75.html |
26th Aug 2023 7:34am |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
Any update for the longgevity of the contacts that have been cleaned?
22nd Feb 2024 7:01pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
did mine in August, working beautifully Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
22nd Feb 2024 8:40pm |
Cheers, I have just gave this a go. Got the started unbolted (what a pain) , and trying to pull it forward out of its housing now.
23rd Feb 2024 5:27pm |
it take patience, many rotations and twists etc to get the right orientation to come out.
23rd Feb 2024 8:07pm |
Thanks, I was pushing it back against the rubber pipe but could not get the teeth past. Will give it a few twists and see how it goes! |
24th Feb 2024 8:54am |
Wiltshire130 Member Since: 05 Aug 2023 Location: Wiltshire Posts: 25 |
However hard I tried I could not get my starter motor out.
25th Feb 2024 2:48pm |
Update, my parallel wire did not fix the fault, but cleaning up the heavily burnt contacts did. Started each time since so hopefully this will last a fair few miles.
26th Feb 2024 7:57pm |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
Would like to give my update to this thread.
27th Mar 2024 12:43pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2489 |
I attempted to extract mine to check the contacts when the starter had to be removed to fit a crankshaft locking tool but I lost patience trying. It was difficult enough to just get it to where I could fit the tool. |
27th Mar 2024 8:32pm |
Shovie Member Since: 04 May 2021 Location: Wickwar area Posts: 14 |
Hi,
6th Jun 2024 4:40pm |
Energising the solenoid makes the high current connection to the main motor, but it also actuates the motor itself, so the spindle is pushed forward and the teeth engage.
9th Jun 2024 8:50am |
Joined the battle of the starter motor removal club today and sure enough the solenoid contacts are the issue. Does anyone know where the permanent live to the alternator is sourced from the live to the starter? My other thought was to move the live to the other solenoid terminal, add a solenoid to the feed on the bulkhead but without knowing where the live to the alternator supply is that idea is a non starter. I have the feeling that as my starter motor was replaced in November 2021 this could be a regular service event, a bulkhead solenoid would save all this pain.
9th Jun 2024 7:59pm |
James23 Member Since: 10 Jul 2024 Location: East Midlands Posts: 9 |
I'm about to have to tackle this job myself as I had a click a few times in the last week.
27th Sep 2024 1:37pm |
