Home > Technical (L322) > Diesel leak 3.6 tdv8
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
I have a diesel leak passenger front under engine
3.6 tdv8
I got underneath car today and spotted this photos below
Has anyone any idea what this pipe is for
Thanks
Post #509996 27th Mar 2019 11:31am
Benner91
It’s the blue collar in the photo
Thanks
Post #509997 27th Mar 2019 11:36am
theres a workshop manual download link in the wiki that might help ..
Post #510001 27th Mar 2019 1:01pm
Benner91
Has anyone any advise on removal of the injector shield I can see 7 bolts but don’t have any tool to remove the bottom bolts is there a flexible drive that could be recommended
Thanks in advance
Post #510016 27th Mar 2019 4:04pm
j_rov
I used a load of wobble bars and flex head ratchet spanners. The ones by the fuel filter are a bitch. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #510023 27th Mar 2019 5:03pm
Benner91
Thanks I’ll order some up
Cheers 🍻
Post #510024 27th Mar 2019 5:08pm
Benner91
After removing shield 7 bolts hatefull job I found my diesel leak on injector return pipe I ordered a new o ring but when I went to replace o ring I noticed that the tip of return pipe on injector return 2nd cylinder on rhs was cracked and came off photo below
What are my options now Big Cry as I can’t drive car now as diesel flying out
Thanks in advance
Can I replace this part or so I have to replace the entire loom
Thanks
Post #510432 31st Mar 2019 6:45pm
j_rov
Is that part of the stiff plastic pipe that fixes to each injector spill off port?
If so, it can be easily replaced with standard off the shelf unions and spill off pipe.
Something a bit like this: https://rover.ebay.com/rover/0/0/0?mpre=ht...1866223237 __
Land Rover History:
1976 Series 3 2.25
Post #510449 31st Mar 2019 8:21pm
Benner91
Hi it’s off the injector spill of unit that fits in to the injector secured by a spring pin
Normally when it leaks you replace o ring but in my case the top of the nozzle were o ring is was cracked and broke off
Can I buy this unit without replacing the whole loom
Thanks
Post #510456 31st Mar 2019 9:01pm
j_rov
Yes, you can replace the tee or corner piece if that’s what’s gone. But you’ll probably need to replace the pipe too as the stock rigid one will most likely crack. __
Land Rover History:
1976 Series 3 2.25
Post #510460 31st Mar 2019 9:15pm
Benner91
Thanks we’re can I purchase a t peace for my Range Rover
Thanks
Post #510461 31st Mar 2019 9:20pm
j_rov
I got some from a local injector specialist. I might have a spare, will check tomorrow __
Land Rover History:
1976 Series 3 2.25
Post #510462 31st Mar 2019 9:29pm
Benner91
Brilliant thanks
Post #510474 1st Apr 2019 6:26am
j_rov
Got one. Pm your address please. __
Land Rover History:
1976 Series 3 2.25
Post #510476 1st Apr 2019 6:40am
Benner91
Has anyone any tips on removing fuel lines from broken leak off injector nipple it’s very tight and I don’t want to damage pipe
Thanks
Post #510481 1st Apr 2019 9:09am
