![]() | Home > Technical (L322) > Diesel leak 3.6 tdv8 |
Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
It’s the blue collar in the photo
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
theres a workshop manual download link in the wiki that might help .. |
Has anyone any advise on removal of the injector shield I can see 7 bolts but don’t have any tool to remove the bottom bolts is there a flexible drive that could be recommended
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
I used a load of wobble bars and flex head ratchet spanners. The ones by the fuel filter are a bitch. __
Thanks I’ll order some up
After removing shield 7 bolts hatefull job I found my diesel leak on injector return pipe I ordered a new o ring but when I went to replace o ring I noticed that the tip of return pipe on injector return 2nd cylinder on rhs was cracked and came off photo below
Is that part of the stiff plastic pipe that fixes to each injector spill off port?
Hi it’s off the injector spill of unit that fits in to the injector secured by a spring pin
Yes, you can replace the tee or corner piece if that’s what’s gone. But you’ll probably need to replace the pipe too as the stock rigid one will most likely crack. __
Thanks we’re can I purchase a t peace for my Range Rover
I got some from a local injector specialist. I might have a spare, will check tomorrow __
Brilliant thanks |
Got one. Pm your address please. __
Has anyone any tips on removing fuel lines from broken leak off injector nipple it’s very tight and I don’t want to damage pipe
