Home > Technical (L322) > Anyone else been so lucky ?
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I bought a new L322 TD6 Vogue back in 2004 and can honestly say in 14 years of ownership absolutely nothing went wrong with the car. It had one recall regarding a front propshaft issue but other than that the only items replaced outside of routine servicing were tyres and wiper blades. The car was parked outside all it's life and the original battery lasted 12 years. I sold it six months ago after buying a used L405 and managed to get 12k for it. Admittedly It had only covered 41 k miles, but surely this is proof that not all LR's are unreliable as the ravages of time take their toll as well as mileage. That said, I don't think my my L405 will be such an easy ride !
Post #508119 9th Mar 2019 8:20pm
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
I had a 2004 TD6 which I ran for 7 years, apart from 2 batteries and routine maintenance was a reliable car. 2004 TD6 - Gone
2011 4.4 TDV8
Post #508122 9th Mar 2019 9:03pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Had my 02 TD6 Vogue for 9 years now and also reliable - 165k. Front prop shaft done , gearbox service and flush (original box) , 2 x injectors and routine maint - also sits outside all the time Smile
Post #508351 11th Mar 2019 10:41pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Similar car to the OP, i had my 2004 TD6 for 12yrs apart from a battery it never let me down once, front prop done under warranty and loads of servicing ( the service book was full at 165,000m when i sold it ) if my current Westie does anywhere near the same i will have been very lucky indeed.
Post #508355 11th Mar 2019 11:16pm
