Home > Technical (L322) > 2012 TDv8 56k miles, White/Grey smoke and oil use
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
the joys of a RR!
having had the turbo mod drain done soon after having the vehicle 42k miles Mar 17, i have enjoyed a wonderful 15k miles or only routine services.....
anyway - low oil wng came on over weekend, took 3+ L to refil to correct level using Hawkeye.
have pondered it for a while then thought its not been used hard lately so drove it hard up through command shift this am.
tonnes of white/grey smoke out the back for 3s above 3000rpm followeded by Restricted Performance, DTCs P042B and P2297
It made a bit of a rattle just before i turned it off.
Cleared the DTCs.
on restart ran lumpy for 2-3s then settled.
pulled out and fine until 3000rpm then white/grey smoke again once. then cleared and ran normal.
So its using engine oil (3L in 2kmiles) and appears to run normally at <2k rpm, but smokes when in higher rev range until i guess the excess oil in the intake has burned off?
what do we think? turbo? Cheers
James
Post #507749 7th Mar 2019 9:58am
Baltic Blue
Have a good look for any signs of oil in the coolant tank and also any leaks around the oil cooler and down the back of the engine.
Post #507750 7th Mar 2019 10:16am
JST
coolant tank is good and clear, no leaks from oil filter housing or the oil feed pipe at back of engine Cheers
James
Post #507759 7th Mar 2019 11:35am
GGDR
What are those error codes James?
. Cheers, Greg
Post #507762 7th Mar 2019 12:02pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
P042B Catalyst temperature sensor – circuit range/performance (bank1 - sensor circuit 2)
P2297 Oxygen sensor out of range during deceleration (Bank 1 – sensor 1) ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #507764 7th Mar 2019 12:20pm
JST
Pulled air intake yesterday, passenger side full of oil. Backfeed from cosv, Also oil in intercooler outlet. Cheers
James
Post #508222 10th Mar 2019 7:16pm
GraemeS
Have you confirmed that the turbo drain mod was indeed done? The revised drain can be spotted looking up towards the back of the engine from near ground level in the vicinity of the left headlight.
Post #508227 10th Mar 2019 7:41pm
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
level
those symptoms are what i would expect of a vehicle overfilled with oil/passing oil
worth draining it,checking amount and refilling with correct amount if there is too much in it
gauges are fine until they fail...
Post #508259 11th Mar 2019 10:12am
JST
Darin mod def been done, in my ownership. it cured a problem at the time with using engine oil, this was approx 15k ago. 2 years.
has now recently (Jan) started using oil again.
my investigation shows it only uses oil above 2500rpm, pulled the air intake and you can see oil just after the air filter in the air ducting, plus oil coming out the intercooler outlet.
i am presuming the oil is coming from the 2nd turbo seals having failed, its leaking and sitting in the ducting/intercooler and then getting blown into engine when the vehicles goes over 2500rpm when CSOV opens.
the oil in the intake after air filter is backfeed from the pipe that joins the air intake just above the location of the CSOV. i am not sure where this pipe comes from. anyone know?
oil level could be wrong, i added to it when vehicle told me it was low, having confirmed level with a Hawkeye. It hadnt been using oil upto Jan 19 though. service was Oct 18, there was some loss of oil due to the sump plug not been done up tight enough! that was all over the underbody tray and very obviously coming from the sump plug.
this is pipe from intake to turbo, oil in here is coming from the small pipe that joins this pipe approx 100mm down from where photo is.
here it is fitted
lots of oil
 Cheers
James
Post #508266 11th Mar 2019 11:39am
GraemeS
Adding 3L of oil relying on the electronic sensor is fraught with danger. I urge you to not rev the engine and to immediately get the oil drained and refilled with the correct volume regardless of what the sensor is showing. If the sensor shows that a lot of oil is still needed then have the sensor replaced. 3L more oil in the engine than meant to be is risking at least blowing seals everywhere and the likelihood of a runaway engine.
Post #508337 11th Mar 2019 7:45pm
JST
ok, i will drain it tomorrow or wednesday and refill.
9l is it to fill complete? presume the filter drains down?
on reflection the vehicle has had lumpy idle and there have been signs of white/grey ish smoke in the early part of this year on initial acceleration. at the time i put it down to cold air temp but it makes a bit more sense now to have been burnt oil.
i stripped out the air intake as i could see the oil here on the join:
prior to adding the 3L so it was entering the air intake before i added 3L to it last monday.
So does no one else add oil when the car tells them to?
anyone know what pipe joins the air intake below that elbow? Cheers
James
Post #508347 11th Mar 2019 9:18pm
Baltic Blue
I think 9 litres is too much as a starting point.
It will take it up to maximum on the gauge when the new oil is cold, but when the engine gets up to normal working temperature it will show as “ Overfilled “
I recommend putting 8 litres in as a starting point.
Then bring it up to temperature. The filter will fill, then top up as required by adding no more than 0.5 litre at a time.
Post #508349 11th Mar 2019 9:34pm
JST
ok 8l thanks.
anyone:
any ideas as to why i would get grey/white smoke over 2500rpm only and have the oil in the air intake prior to adding the 3L? Cheers
James
Post #508350 11th Mar 2019 9:35pm
GraemeS
That pipe goes to the change-over valve. The oil could be there because the sump is over-filled or due to a failure of a turbo or possibly the crankcase ventilation system.
Mine has never needed oil between my earlier 15K km and now 10K km changes, let alone getting down to requesting that oil be added.
Post #508352 11th Mar 2019 9:46pm
JST
thank you for info on the pipe.
neither has mine used oil between services since the drain mod , but reality is i have oil coming up that pipe prior to adding the 3l it was definitely burning the oil prior to the add of 3L.
so overfilled or not its burning oil.
i personally do not believe its overfilled.
i believe the larger turbo has gone, oil is sitting in the CSOV until the engine is opened up and then it gets burnt off or comes up that pipe and contaminates the new pre turbo air coming in which then gets burnt off.
how would these symptoms differ to a turbo seal having failed. Cheers
James
Post #508353 11th Mar 2019 10:03pm
