![]() | Home > Technical (L322) > 2012 TDv8 56k miles, White/Grey smoke and oil use |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2577 ![]() ![]() ![]() |
Its probably time to get a professional opinion especially if you determine that the sump is not overfilled. |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
i concur, just have a 3 week wait before any reputable around here can look at it! |
Oil drained and refilled, it had 8L in it. Cheers
Not good. Is the level indicator therefore accurate enough? |
i believe the level indicator is functioning correctly. Cheers
its at the menders, a very reputable independent, new fixed vane turbo going in. Cheers
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Did you get this sorted James?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4326 ![]() ![]() ![]() |
Somerset area?? I'd be taking it to T&S Norman ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
