![]() | Home > Technical (L322) > Rear seats folded shut |
The simple answer is NO they will NOT fit...
AutoBiL322 Member Since: 10 Feb 2019 Location: Bath Posts: 42 ![]() ![]() |
It would be crazy to mess with the airbags. I just want the seats in.
I’ve. Been asked to do it several times and refused. One of my customers bought a 2004 with a late interior fitted, we took the front seats out to see if we could make the electrics work and someone had welded in bits of angle iron etc to make a frame for the later front seats to mount to...
Interesting as I have heard they just needed a pin removing to slot in as normal. No idea what that meant.
You seam unconvinced Bil... Why don't you put a tape across the front bolts of your drivers seat, then ask someone here to measure the front bolt width on an 07> you will then have the relevant measurements sir |
It’s not so much about being unconvinced. You have been really helpful.
Update on this ... sadly the 2012 seats will not fit. Not because they are too wide but because the later seats are narrower.
A further update as info so hard to come by.
I did give you the dates above sir! The seats changed with the 2007 interior facelift! So, to be clear...
That’s not correct unfortunately.
Maybe you can ask the kind members on here to measure their seats...
I have asked several breakers as well as measured the 2012, 2003 and 2006 seats I have in my possession. 2003 Autobiography 4.4
OK no problem...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
very diplomatic Craig |
