Home > Technical (L322) > Rear seats folded shut |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
The simple answer is NO they will NOT fit...
9th Mar 2019 9:41am |
AutoBiL322 Member Since: 10 Feb 2019 Location: Bath Posts: 42 |
It would be crazy to mess with the airbags. I just want the seats in.
9th Mar 2019 12:08pm |
I’ve. Been asked to do it several times and refused. One of my customers bought a 2004 with a late interior fitted, we took the front seats out to see if we could make the electrics work and someone had welded in bits of angle iron etc to make a frame for the later front seats to mount to...
9th Mar 2019 4:13pm |
Interesting as I have heard they just needed a pin removing to slot in as normal. No idea what that meant.
9th Mar 2019 5:35pm |
You seam unconvinced Bil... Why don't you put a tape across the front bolts of your drivers seat, then ask someone here to measure the front bolt width on an 07> you will then have the relevant measurements sir |
9th Mar 2019 7:00pm |
It’s not so much about being unconvinced. You have been really helpful.
9th Mar 2019 9:03pm |
Update on this ... sadly the 2012 seats will not fit. Not because they are too wide but because the later seats are narrower.
10th Mar 2019 1:52pm |
A further update as info so hard to come by.
18th Mar 2019 10:22am |
I did give you the dates above sir! The seats changed with the 2007 interior facelift! So, to be clear...
18th Mar 2019 10:45am |
That’s not correct unfortunately.
18th Mar 2019 12:42pm |
Maybe you can ask the kind members on here to measure their seats...
18th Mar 2019 1:10pm |
I have asked several breakers as well as measured the 2012, 2003 and 2006 seats I have in my possession. 2003 Autobiography 4.4
18th Mar 2019 1:28pm |
OK no problem...
18th Mar 2019 1:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
very diplomatic Craig |
18th Mar 2019 3:22pm |
