Home > Technical (L405) > Dynamic Response Resvervoir
Hendersonmum
United Kingdom 2013 Range Rover Vogue TDV6 Luxor
Hello...
I have just had my 3.0 TDV6 in for a service and one of the points from the health check was that the filter in the dynamic response reservoir needs replacing but this can only be done by replacing the whole reservoir and at quite a price!!
I joined your forum to find out my options and have only seen posts that suggest that it is only installed in the SDV8 and so now I’m really confused.
Can anyone advise please..?
Post #507084 2nd Mar 2019 11:55pm
RRSuperc
United Kingdom 2013 Range Rover Autobiography 5.0 SC V8 Luxor
Is this at the main dealer, yes as far as I am aware only the SDV8 and Supercharged have it. They might be taking you for a ride
Post #507511 5th Mar 2019 7:45pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Heres mine on my 5.0 S/C, took the picture the other day as thinking the fluid level is low but wasnt on flat ground so cant be sure.
3.0 doesnt have this system so no reservoir AFAIK
P.S Sorry the pitctures rotated round, dont know how to turn it back Rolling with laughter
Post #507515 5th Mar 2019 8:33pm
I think the OP has now filled in his car profile 👍
Post #507540 5th Mar 2019 10:32pm
Hendersonmum
Thank you RRSuperc, yes Harwoods in Basingstoke, surely they wouldn’t do that? :
Post #507624 6th Mar 2019 3:37pm
Hendersonmum
Thanks carlos50, oh dear, I’m more comnfused than ever, very glad I didn’t fork out for the new reservoir at the time, needed thinking time. So do I call them and tell Harwoods this can’t be right?
Post #507626 6th Mar 2019 3:43pm
RRSuperc
Hendersonmum not uncommon over the years I have had quite a few experiences when main dealers just make stuff up and tell me parts need replacing or changing when it hasn't been the case, it's easy money to cash in from customers who have no idea and just pay up as they believe them being a main dealer ........ Just tell them how can it need changing when to my knowledge I don't believe my car even one to replace the filter on and see what they say !!
Post #507692 6th Mar 2019 9:52pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
I hope this post will help people.
My 2014 RR Autobiography went in as I kept getting a suspension fault. The main dealer reported back that I had a hydraulic line weep and the pipe needed to be replaced. It would not be covered under warranty for some BS reason...they wanted 22 hours labour which was just over £4000 plus VAT....after my shock response it dropped by £1000 "as they wanted to look after me"
I took the car away and got the friendly chaps at Pirtek to come out, they replaced the leaking part on my driveway with the front passenger side jacked up, 1 hour later and £120 plus VAT the car is fit as a fiddle.
The reason the part had corroded is that LR had a piece of sponge attached to the pipe that holds water and corrodes the pipe. this should be warranty work or recall IMO.
Post #507765 7th Mar 2019 1:24pm
carlos50
Was that causing the fluid level to drop, I dont have any messages so was going to top it up and monitor it?
Post #507767 7th Mar 2019 1:36pm
carlos50
Topped mine up today, needed approx 100ml
Noticed how dark the fluid was compared with the new stuff and the top up made a difference in ride firmness, will keep an eye on it to make sure it doesn’t drop straight away
Post #508004 8th Mar 2019 6:37pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I found the same with darker looking oil so I sucked the oil out of the reservoir and replaced with fresh. It won't have removed all the oil but at least some of the dirtier looking stuff has been removed.
Post #508072 9th Mar 2019 1:06pm
carlos50
Thinking of doing the same, what did you use and did you just put into the reservoir
Post #508075 9th Mar 2019 1:16pm
roberlar
I sucked the oil out with a Silverline suction pump. Its about the same size as a grease gun and less than £10 from Amazon. I then topped the reservoir back up with Ravenol SSF Cold Climate fluid and all seems fine. Not as good as a total change but better than no change. I suppose if you ran the car and repeated the process once or twice it would remove most of the old fluid without getting in to more complicated options.
Post #508081 9th Mar 2019 1:53pm
carlos50
Were you able to put the tube down the reservoir pipe or did you just sit it in the reservoir and suck as much as possible?
Ive got appox 900ml of the bottle i got the other day and just bought another 1L along with the 4L Silverline suction pump (will use for other fluids possibly), how much did you get out?
Post #508134 9th Mar 2019 11:13pm
roberlar
I sucked the oil directly out of the reservoir leaving a small amount in the bottom, probably about 200-300 ml taken out. As said, if you drive the car and then repeat in theory it should get cleaner each time. Providing the engine isn't running during the process it shouldn't do any harm and removes a fair amount of the old fluid and any suspended crap quickly and easily. Not as good as a complete change of course
Post #508186 10th Mar 2019 3:21pm
