![]() | Home > In Car Electronics (L322) > Radio stops working after CD changer is disconnected |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
the nav, BT, radio etc are all connected together in one optic fibre circuit..take one out and it all stops working..
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 ![]() |
By vertical position I mean that CD changer is hanging out of glove box facing to ground. So there is no way to remove CD changer without affecting others? I would need to install tachograph instead of that, would it be possible to move it to trunk somehow? |
i dont know how the connections look but you could try the bic biro method which is used to remove the BT unit out of the circuit ..do a forum search for more info re that.. |
broncoupe Member Since: 21 Nov 2011 Location: bournemouth Posts: 70 ![]() |
if you want to remove it completely you loop it out
