Home > Maintenance & Mods (L405) > L405; Limp mode due to P040D-00 (2F) - which sensor is it?
Tore2ls
Scotland 2014 Range Rover Vogue SDV8 Baltic Blue
Dear All,
I have read:
Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement
https://www.fullfatrr.com/forum/topic50202.html
I have:
What I can't confirm is which sensor is Bank 2 - Sensor 2, I believe it to be faulty as reading 0 degrees and volts. But why would this generate a fault code P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high. Why high if 0V?
I can't find it identified on Topix
I believe it might be LR035741, Pre DPF Temperature Sensor? Does anyone know? (Left hand side of the engine on the exhaust down pipe - see below)
To help trouble shooting, if I disconnect this sensor from the loom what voltage should it be?
Am I heading the right direction with my logic based on the IID screen shots attached Question
Post #505061 13th Feb 2019 10:07pm
GGDR
Hi you won't find this on your IIDTool readings. And you will find Sensor 2, Bank 1 etc are dead ends. I've been through a few months of investigation as you may have read in those posts.
Can I just check you have read them? I'm only asking because you seem like you are still searching but I can say conclusively, note my screen shot at the beginning of https://www.fullfatrr.com/forum/topic50202.html which also says ....circuit high. Perhaps I should make it clearer?
That code, as those two threads conclude, relate to a fairly undocumented temperature sensor on the NS (that is right hand side if standing in front of the car) exhaust manifold. It's not on or near the EGR, DPF or Cat converter.
It's a common error however it is unusual that you have limp mode from that.
So I think you may have another cause of limp. Check the intake hoses very carefully for cracks. You may need to remove the hoses to check as they can crack under the clips. When these go there can be no error code present and you can get restricted performance.
Do you have any other errors? Here to help.
Also, no screenshots in your OP.
. Cheers, Greg
Post #505067 14th Feb 2019 4:35am
Tore2ls
@gonna_go_double_r
Thank you for the feedback. Picture should be up - forgot the click to add!
I'll check the hoses, but it is definitely the only fault code currently Exclamation
I have read it again
I'm now confused Confused
I was under the understanding there could be a couple of temperature sensors link to this fault code given that Bank 2 - sensor 1 is correct reading 100 deg c until you boot it?
You then use the IID to understand which sensor is not working?
Both are on the NS but it could be LR052169 or LR035741
I understood Bank 2 - sensor 1 to be LR052169 but this may not be correct?
Once I get into the guts of the bonnet this weekend I will pull both sensors to see if it changes the IID reading[/quote]
Post #505114 14th Feb 2019 2:29pm
Baltic Blue
A split in any of the 4 short hoses or along one of the seams on the plastic plenum will give rise to restricted performance messages, but not raise any fault error codes.
Both are very common failings in 4.4tdv8 l322’s.
Post #505115 14th Feb 2019 2:38pm
GGDR
[/quote]
I wouldn't bother, none of those sensors or values affect this error code, just check hoses first. Thumbs Up
. Cheers, Greg
Post #505154 14th Feb 2019 8:11pm
Tore2ls
Thank you - hoses first point to check, i'll feed back on findings Bow down
I can see some oil/soot on one. NS rear (closest to the bulkhead) It does not look like any are split, but ill need to remove them to see the underside.
The car has only been in limp mode in the cold weather
Also goes into limp mode when holding it in gear and going down hill.
Post #505214 15th Feb 2019 12:34pm
Baltic Blue
The hoses have already been changed to the newer design so should be OK if the clips are tight enough.
Post #505220 15th Feb 2019 1:29pm
Tore2ls
Thanks Mike. Good to know they updated them for the 2014 model.
Does any one else have hooting noise like a pigeon when taking their foot off the throttle?
When I accelerate averagely, throttle say 2000 rpm and then take my foot off the throttle i get the noise? I always put it down to the turbos, but its not a sustained turbo whine, its a pulsed hoot of three pulses.
You don't hear it at high revs or speed due to noise. Confused
Post #505222 15th Feb 2019 1:59pm
GraemeS
The flutter when backing-off is likely to emanate from the primary, variable vane turbo as it adjusts to accommodate the changed airflow, possibly in conjunction with the closing of the secondary turbo inlet isolation valve.
Post #505282 15th Feb 2019 8:03pm
Tore2ls
Well I still have no idea what Bank 2 Sensor 2 is?
From testing I know that Bank 2 Sensor 1 is on the NS down pipe post turbo, pre DPF Temperature Sensor. LR035741.
This is accessible underneath with a 14mm spanner.
I removed the sensor and it was slightly sooty and with some oil (think I have a turbo issue). To test it's i put a small blow torch on the exposed sensor with the IID tool and could see Bank 2 Sensor 1 increasing from its ground/base value of 100 deg. C.
This was working as it should, but note getting the sensor disconnect would be difficult due to space getting ones hand up. Either drop the gearbox frame or remove the prop shaft.
So I moved to the NS Exhaust Manifold Temperature Sensor LR052169 (9J460D)
To test I never removed the sensor, but disconnected it and checked the resistance accross the pins of the sensor plug. The circuit was broken so I knew there was a problem. I checked the new sensor and it has a resistance 250 ohms. I then connected the new sensor to the loom and checked the IID and the fault code disappeared.
I then tried to check if this was Bank 2 Sensor 2, however it does not appear to be. Even when heat was applied to the new sensor Bank 2 Sensor 2, voltage and deg. C. remained at 0.
To access the sensor on the L405 I removed the fuel filter.
As per advice in the forum, thanks, I intentionally broke the sensor to get a 6 sided socket over the sensor. This was required as I needed to put a high torque on It to remove it.
On another not could limp mode be generated by a leaking turbo?
Post #505477 17th Feb 2019 3:57pm
GGDR
Geez well done you have been busy.
Glad you got rid of the error code, changing the manifold sensor is quite a job.
I liked your simple test of plugging it in before fitting, nice Thumbs Up
It was also good to see how different access is on the 405.
Your long articulated socket / extensions combo seemed to do the job!
Good to see the long tube on the WD40 bottle too! Thumbs Up
But your limp mode remains. Sad
One not-so-obvious thing to check - when I changed my air filters, I forgot to plug the air sensor back in and it started in restricted mode. No errors on the IID were showing but then when I realised I plugged the sensor back in and it went away.
Maybe a sensor or connection could be loose?
Have a good root around if you haven't already.
. Cheers, Greg
Post #505480 17th Feb 2019 4:22pm
GGDR
The ECU needs it but it's undocumented as far as the IID values go. I even asked Gap why not and they said it is not a monitored value as far as LR goes so it's not included.
. Cheers, Greg
Post #505481 17th Feb 2019 4:24pm
Tore2ls
Thanks @gonna_go_double_r. The effort in your write up really helped get the sensor change in an afternoon as opposed to a long time head scratching - which is evident you had to do!
Post #505564 18th Feb 2019 1:18pm
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
Isn't this noise just a turbo actuator. (Dump valve )letting off pressure .
Mine does it .4.4 tdv8 2011.
Post #556355 3rd Jun 2020 12:54pm
Tore2ls
Landyandy1765, I think you are correct. The noise was nothing to do with the problem. The issue was a different temperature sensor that wasn't showing up on the fault code reader. The faulty temperature sensor was just before the cat and DPF.[/quote]
Post #556381 3rd Jun 2020 4:15pm
