Home > Maintenance & Mods (L405) > L405; Limp mode due to P040D-00 (2F) - which sensor is it? |
Tore2ls Member Since: 18 Sep 2017 Location: Aberdeen Posts: 9 |
Dear All,
13th Feb 2019 10:07pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Hi you won't find this on your IIDTool readings. And you will find Sensor 2, Bank 1 etc are dead ends. I've been through a few months of investigation as you may have read in those posts.
14th Feb 2019 4:35am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
14th Feb 2019 2:38pm |
[/quote] I wouldn't bother, none of those sensors or values affect this error code, just check hoses first. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
14th Feb 2019 8:11pm |
Thank you - hoses first point to check, i'll feed back on findings
15th Feb 2019 12:34pm |
The hoses have already been changed to the newer design so should be OK if the clips are tight enough.
15th Feb 2019 1:29pm |
Thanks Mike. Good to know they updated them for the 2014 model.
15th Feb 2019 1:59pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
The flutter when backing-off is likely to emanate from the primary, variable vane turbo as it adjusts to accommodate the changed airflow, possibly in conjunction with the closing of the secondary turbo inlet isolation valve. |
15th Feb 2019 8:03pm |
Well I still have no idea what Bank 2 Sensor 2 is?
17th Feb 2019 3:57pm |
Geez well done you have been busy.
17th Feb 2019 4:22pm |
The ECU needs it but it's undocumented as far as the IID values go. I even asked Gap why not and they said it is not a monitored value as far as LR goes so it's not included. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
17th Feb 2019 4:24pm |
Thanks @gonna_go_double_r. The effort in your write up really helped get the sensor change in an afternoon as opposed to a long time head scratching - which is evident you had to do! |
18th Feb 2019 1:18pm |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 |
Isn't this noise just a turbo actuator. (Dump valve )letting off pressure .
3rd Jun 2020 12:54pm |
Landyandy1765, I think you are correct. The noise was nothing to do with the problem. The issue was a different temperature sensor that wasn't showing up on the fault code reader. The faulty temperature sensor was just before the cat and DPF.[/quote] |
3rd Jun 2020 4:15pm |
