Home > Maintenance & Mods (L405) > L405; Limp mode due to P040D-00 (2F) - which sensor is it? |
Tore2ls Member Since: 18 Sep 2017 Location: Aberdeen Posts: 9 |
The gremlin for me was two temperature sensors. The one I replaced in the pictures earlier in the thread and one further down the exhaust near the DPF.
3rd Jun 2020 4:36pm |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 |
Well following the advice on the Egr temp sensor 2 i started and found that this in the most awkward place possible .
14th Jun 2020 4:17am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
yes tool will open up if used for removal so you did the right thing by cutting off end to get socket on for removal. Pre soaking would have probably saved some effort. Well done !
14th Jun 2020 5:53am |
[/quote] i changed my Sensor and now the code has cleared and now im seeing a EGR regen as it didnt before . Not had a problem since |
12th Apr 2021 2:11am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3818 |
I have been advised that this can safely be ignored - can it?
22nd Jan 2022 9:58am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Geoff, does your exhaust stink when running? My car smelt like an old ice cream van whilst the engine was running in a confined space… When I reversed mine in the garage at night it was very obvious! This was caused by the failure of the N.S. exhaust manifold probe, in the cool position. This resulted in my car overfueling, effectively running on choke and filling theDPF with unburnt diesel fuel!!!
22nd Jan 2022 10:42am |
Thanks Craig,
22nd Jan 2022 10:58am |
The actual message from my car this afternoon is
23rd Jan 2022 2:38pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Geoff,
23rd Jan 2022 3:01pm |
2017,
23rd Jan 2022 3:28pm |
Thanks BB, that is the advice I have been given (not from the Indie at £300 a pop it's easy money for them) so I think I'll just run with it. Now I just need to get the DPF upgrade for my IIDTool to ensure regions are taking place normally.
23rd Jan 2022 7:32pm |
Captain_67 Member Since: 26 Feb 2024 Location: Ellesmere Posts: 14 |
Sorry to raise this given the amout of pain it caused
26th Feb 2024 5:03pm |
