![]() | Home > Maintenance & Mods (L322) > Coding advice/help for Westie |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Yes to both your questions re the running lights and speed readout. Just my opinion but the IID TOOL is worth every penny and is a very handy piece of kit to carry in the RR. 2015 4.4 AB
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35618 ![]() ![]() |
the fairy drl lights are a waste of time as they arnt very bright but the digital mph is handy ..
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
I like the fairy lights. Think they look good.
topgeartowers Member Since: 23 Mar 2010 Location: London Posts: 82 ![]() |
Thanks for the replies so far.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
Yep, I have my main beams switched on as DRL's and a digital speed readout, both courtesy of the IID tool.
The IID TOOL can store the 'original ' settings in case of user errors !! It can also store original engine map if you get yours remapped. Great bit of kit. Re the DRLs , the fairy lights look well but not much use during a bright day. 2015 4.4 AB
What’s Dan’s forum name? Cheers! |
The fairy lights don't appear bright when out in the sun but place your car in a country lane in the autumn and they may make the difference between someone spotting you or not! |
Ok I think I’ve worked out Dan is from Duckworths.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Go to GAP. DIAGNOSTICS for their online guide and read up on here what members have done too. Cheers
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I saw a Sport the other night with just his fairy lights on (didn't realise they had them). It was almost invisible in the dark.
probably had just his side lights on... |
Good info on this forum - just dig ![]() And Patrick at GAP is extremely helpful - and friendly. But one from Dan and enjoy being able to change the configuration of your FF. Plus have the peace of mind should you ever get the dreaded 'bong'. What do I put here then? |
Thanks lads! |
