Home > Technical (L322) > FBH operation with timed climate |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Following with interest -- as I get E7 on every attempt Current: 2011 FFRR Vogue SE 4.4 TDV8
15th Jan 2019 3:58pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Not that this helps, but mine works fine from the timed climate and the remote, but not the manual option on the screen!
16th Jan 2019 7:54am |
You get the E7 when testing with IID, I have failed everyone to get IID to connect to the FBH,
16th Jan 2019 8:15am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
The FBH is a fickle system.
16th Jan 2019 8:37am |
Yes, it is. I can't remember if that's the correct fuse, but I reset mine a few times by pulling one of the underbonnet fuses when it was previously misbehaving. 2010 4.4 TDV8 Vogue SE |
16th Jan 2019 2:36pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
What's the fuse pulling process? When engine off or running?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Jan 2019 3:52pm |
Pulling the fuse is no guarantee of clearing the fault codes. Better to use a fault code clearer even the cheap ones do the trick. |
16th Jan 2019 4:05pm |
Thanks Kooky
16th Jan 2019 5:22pm |
It sets an OBD11 code after 3/5 no starts or fuel too low that needs to be cleared before it will start again. I was saying any budget code reader will cear it via the OBD11 port..
16th Jan 2019 5:45pm |
Gary, thanks that makes sense, so the fact the IID can't communicate with it suggest something more fundamental than a simple reset by removing the fuse I would suspect! Other than the fuse being blown I suppose!!! Current: 2011 FFRR Vogue SE 4.4 TDV8
16th Jan 2019 7:13pm |
Engine off, I think. Just left it out for a 30 secs or so and put it back in again. That then allowed the fbh to try again rather than it being completely locked out. 2010 4.4 TDV8 Vogue SE |
17th Jan 2019 8:52am |
tractorfactor Member Since: 22 Dec 2018 Location: wales Posts: 10 |
Hi All,
20th Jan 2019 9:03pm |
20th Jan 2019 9:28pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Hi TF,
23rd Jan 2019 8:48am |
