![]() | Home > Technical (L322) > FBH operation with timed climate |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Mine wouldn't run at 11.4V, although the car itself was perfectly happy. 2010 4.4 TDV8 Vogue SE |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
I had the E7 fault and the FBH wouldn't operate. Cured it with a 'Vehicle Reset' with the IID ... Regards,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
as above the FBH needs a min battery voltage.
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
What does this actually do? I’ve seen this in IID. I’m getting E7 as well. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
tractorfactor Member Since: 22 Dec 2018 Location: wales Posts: 10 ![]() ![]() ![]() |
Hi all,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Good news. When it works it’s |
Good to hear. I wish I could get mine working without having to remove all of the wheel arch liner! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
hi Andy
It doesn’t fire up. It sounds like it’s trying with the jet turbine sound from inside the wheel arch then it changes to a fan running. The fuel pump doesn’t start although it did one one occasion briefly. Like a ticking sound from the back. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Hi Andy,
I have pulled the fuse a couple of times but it doesn’t make any difference. I’ve tried to check the operation with the IID tool but just keeps failing with a fault code which no-one seems to know what the code is.
Do you have any more information on the software update? It seesm odd that a car of your age would have out of date software - I assume this relates to the battery managenment? 2010 4.4 TDV8 Vogue SE |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Hope you don't mind if I hijack the thread with a query re the FBH. I have a 2020 autobiography and the FBH works fine off the JLR remote fob but when I try to use it via the inControl app it starts the engine after about 20 seconds. Is this normal? Agueroooooooooo. 93-20
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
This is in the L322 Technical Section, so not many L405 owners looking in here.....
