![]() | Home > Technical (L322) > FBH operation with timed climate |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Following with interest -- as I get E7 on every attempt |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Not that this helps, but mine works fine from the timed climate and the remote, but not the manual option on the screen!
You get the E7 when testing with IID, I have failed everyone to get IID to connect to the FBH,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
The FBH is a fickle system.
Yes, it is. I can't remember if that's the correct fuse, but I reset mine a few times by pulling one of the underbonnet fuses when it was previously misbehaving. 2010 4.4 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
What's the fuse pulling process? When engine off or running?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Pulling the fuse is no guarantee of clearing the fault codes. Better to use a fault code clearer even the cheap ones do the trick. |
Thanks Kooky
It sets an OBD11 code after 3/5 no starts or fuel too low that needs to be cleared before it will start again. I was saying any budget code reader will cear it via the OBD11 port..
Gary, thanks that makes sense, so the fact the IID can't communicate with it suggest something more fundamental than a simple reset by removing the fuse I would suspect! Other than the fuse being blown I suppose!!! Current: 2011 FFRR Vogue SE 4.4 TDV8
Engine off, I think. Just left it out for a 30 secs or so and put it back in again. That then allowed the fbh to try again rather than it being completely locked out. 2010 4.4 TDV8 Vogue SE |
tractorfactor Member Since: 22 Dec 2018 Location: wales Posts: 10 ![]() ![]() ![]() |
Hi All,
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Hi TF,
