Home > Technical (L322) > Oil leak
GGDR
thanks cheezels for the steering info.
Will try to get to look at those bolts.
A quick check this morning - my fluid level is perfect.
. Cheers, Greg
Post #501482 14th Jan 2019 9:22am
DrRob
Diagnosis in. Oil cooler gaskets (I was dreading it might have been a turbo Big Cry )
Also having EGRs replaced at same time. Showing intermittent fault so get them done whilst stripped down for the gaskets. Will save on any future labour costs.
I wonder if it was leaking when I bought it but previous owner had it all cleaned off for the sale? Whistle Censored
Good job I don’t have kids and spend my dosh on motors instead Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501537 14th Jan 2019 4:47pm
GGDR
Dr Rob, there is a common EGR fault code....
It relates to a prode in the NS exhaust manifold.
Changing the EGR may be a waste of money.
. Cheers, Greg
Post #501538 14th Jan 2019 4:51pm
GGDR
The code is: P040D-00 (2F) Exhaust Gas Recirculation Temperature Sensor A - circuit high
. Cheers, Greg
Post #501539 14th Jan 2019 4:52pm
DrRob
OK, thanks. Will ask....
It’s a probe you say? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501543 14th Jan 2019 5:03pm
GGDR
If you are getting that error code it's a probe (sensor) around £75.
But It'll cost a bit a labour on top of that:
https://www.fullfatrr.com/forum/topic48131...2f+exhaust
. Cheers, Greg
Post #501544 14th Jan 2019 5:09pm
GGDR
(Sorry about the typo)
. Cheers, Greg
Post #501545 14th Jan 2019 5:10pm
DrRob
Looks like it’s chepaer and easier to get a main dealer to change out the NS sensor.....who’d have thought that Whistle Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501556 14th Jan 2019 6:17pm
DrRob
I'm going to get the EGRs done anyway (only money!)
Bought an IID and will see if I get the code error in future...
I can feel myself getting sucked in Rolling with laughter Rolling with laughter
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501637 15th Jan 2019 12:17pm
DrRob
EGRs not being replaced. A vacuum pipe was found to be disconnected which probably threw up the intermittent EGR fault error codes on the diagnostic.....
IID on its way for more owner mither and worry Rolling with laughter Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501803 16th Jan 2019 3:47pm
L322 Newbie
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
Hi all,
Bought my RR 3.6 TDV8 in Feb 2017, since then have had numerous water and oil leaks, with respect to oil leaks:
1, Main oil cooler
2. Gearbox cooler
3 Front differential drivers side output drive seal leakage
4. Main gearbox cover seal leakage
5. Output drive seal leakage from from front differential-still to rectify
6. Steering rack leakage
Drive is still covered in spots and a nightmare - still the car is drivable and a great car- what man made man can fix is my motto.
Steve Steve
2007 L322 RR Autobiography Black
1999 X100 Jaguar XKR Black
2008 Smart 451
Post #501808 16th Jan 2019 4:19pm
Nick591
Steve what was your main oil cooler leak? Cooler itself or gasket? How did it show up on the car (i.e where did you see the oil)? Did you fix it yourself and if so how difficult was it? What age and mileage is your FF?
Thanks, Nick Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #501958 17th Jan 2019 10:45pm
