Home > Technical (L322) > Help It won't start after engine swap. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Diagnostics will tell you if you have lost the link but if your fuel pump is running and you have pressure at the Schraeder valve then link is ok. You can also test to see if you have a spark at the plugs.
17th Dec 2018 12:29am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
They always start on petrol in order to get the required heat into the evaporator. Can you smell petrol at the exhaust? if yes then it's injecting but no spark at the right time. If no then the injectors are not pulsing - check the wiring, 12v feed etc. One possibility that I have seen on V8's is to get the ignition timing 180 deg out. Check that when No1 is on compression that No.1 is firing.
17th Dec 2018 6:27am |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
Had something very similar to this on another car a few years ago. In my case it was the ECU needed coding to the engine and in turn to the key. 2006MY 4.2 SC
17th Dec 2018 5:04pm |
The EWS immobiliser is matched to the Bosch engine management which when mine losed that link it would crank and not start. The immobiliser prevents the fuel pump feed and also disables the ignition so if there is fuel pressure and a spark then that is something else.
17th Dec 2018 5:38pm |
shedjim Member Since: 30 Jul 2016 Location: in the east Posts: 7 |
Thanks all,
17th Dec 2018 9:10pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 327 |
Have you not connected the IiD tool - should suggest where the issue lies or read some codes at least ? 4.2 SC - sold , now bought back
17th Dec 2018 9:17pm |
Not yet I didnt have time, I was a bit to late in my workshop for a Sunday night and can't get back in there until Thursday.
17th Dec 2018 10:04pm |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 |
Gap IID Tool Pro
17th Dec 2018 10:42pm |
thought it might not be easy to find so here you go.
18th Dec 2018 1:14pm |
It's running
22nd Dec 2018 11:51am |
22nd Dec 2018 7:16pm |
