Home > General > bit of a curiosity question
for those with a 'stop/start' button, when starting do you press the brake pedal first and then the start button, or vice versa ..
i've always done the pedal and then the start button and had a second or two delay in starting but the other day i tried the start button first and then pedal and found the FF started instantly...
[yes i'm bored Mr. Green ]
Post #498394 13th Dec 2018 10:21am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I always thought the delay was to allow the glow plugs time as the delay is longer when it’s cold.
Ian
Post #498396 13th Dec 2018 10:26am
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I always press the brake then the start button but can't wait to get home to try the other way round.
I also thought the delay was very clever, to allow the glow plugs to get to temperature before trying to start. In the old days with some cars you turned the key part way until the glow plug light went out then you could start the engine.
Post #498397 13th Dec 2018 10:42am
i figured glow plug warm up as well ..
pressing the start button first maybe does this and by the time you press the pedal , the plugs are ready to go...
Post #498398 13th Dec 2018 10:45am
Another vote for pedal first and had assumed a glow plug delay. Mine definitely takes longer before it starts when it’s cold.
For a complete answer - I put my seatbelt on whilst waiting for it to start and the gear selector rising.
Post #498399 13th Dec 2018 10:46am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Always brake pedal then button - until now Very Happy Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #498400 13th Dec 2018 10:53am
Mr Tee
Slow day Stan?? Pedal first for me .
Post #498408 13th Dec 2018 12:34pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Pedal first for me, when cold turns over stops, I believe to move oil around and glow plugs warm up then starts no problem.[/quote]
Post #498418 13th Dec 2018 1:57pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Stan,
Could you perhaps test (as best as humanly possible) simultaneous 'pushing' and report results Whistle
Thanks
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #498419 13th Dec 2018 2:07pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Have done both and sometimes realise I am pressing the button as my foot heads to the pedal!
Definitely takes longer if it is cold but never thought about the glow plugs warming on the press of the starter button - very possibly true - good spot 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #498420 13th Dec 2018 2:09pm
ajac8
The handbook says pedal first so that the way for me.
Anything else will only end in tears Stan!
I assume its stated that way for the glow plug reason.
Incidentally I know from not think correctly one day that a simultaneous press of both button and pedal also results in an immediate start. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #498423 13th Dec 2018 2:17pm
i cant see that starting the 'alternative' way would harm anything as pressing the start would heat the glowplugs and the pedal would start the FF...
maybe because the way specified in the owners manual , the delay when you press pedal then start, does the same glowplug 'heat up' process...
Post #498426 13th Dec 2018 2:27pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
...some of my postvintage cars have glow plugs and starter buttons, they have celebrated their 80th birthday or more, the automotive industrie has made huge steps forward, i see.... Laughing Sorry only joking
Post #498431 13th Dec 2018 3:05pm
CS
Having been advised by a dealer that it is better to allow the system to boot up before starting the car (as also done on motorcycles nowadays) I press the start button and then when prompted to do so put foot on brake and press starter again. I used to put foot on brake and press starter, that generally worked but in my 405 I occasionally got error messages like "gearbox fault" which are obviously not attractive. Software updated and no longer get such messages, but still follow the 'boot up first' approach. Only Range Rovers since 1988
Post #498454 13th Dec 2018 4:36pm
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
Footbrake then button for me. I can't imagine it makes any difference as the car systems decide what happens next. The glow plugs are heated when needed on a start but don't come on once warm. The car knows what's going on and gets on with it. I think! Happy to let it continue doing it's thing tbh.
Post #498467 13th Dec 2018 6:27pm
