Home > General > bit of a curiosity question
405's & late model D4's start much quicker than 322's Stan... There always seams to be a small delay when i get into 322's AND, more often they won't turn over because i either don't press the button or the brake peddle hard enough!
Post #498470 13th Dec 2018 6:38pm
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
I’m pedal first too! Does anyone find that you really have to press the pedal quite hard to register with the car that it’s being pressed? Maybe I’m a whimp but have always been surprised at the pressure requires!
Post #498472 13th Dec 2018 6:47pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
L322 has a whole different starting system. The button itself mirrors turning a key, hence why you need to hold it rather than a simple press like the more modern vehicles.
Post #498507 13th Dec 2018 10:00pm
Garnerj
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Pedal first then button for me
Post #498511 13th Dec 2018 10:23pm
Ahh now that makes sense... Thumbs Up
Post #498512 13th Dec 2018 10:41pm
GGDR
Definitely take a second longer with the cold weather....
. Cheers, Greg
Post #498517 13th Dec 2018 11:29pm
Autobiography
Indeed. The L322 from 10MY is actually a very old electrical architecture dressed up so to speak.
Post #498522 14th Dec 2018 12:34am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Not on mine, press and let go then it fires up when ready.
Ian
Post #498544 14th Dec 2018 9:47am
drakes
Agree with IanV8 even on earlier models with the key you could turn the key then let it go and the engine would crank until it started, I have a Merc that does the same. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #498561 14th Dec 2018 11:24am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Same here, no delay, fires straight up. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #498562 14th Dec 2018 11:47am
No delays on the petrol SC - and only need a short press as it will fire when ready. I've got glow plugs on my tractor tho so know what you guys are going through Laughing Mike - MPx
Post #498658 15th Dec 2018 12:12am
Double post... Embarassed Mike - MPx
Post #498659 15th Dec 2018 12:13am
dolph34
+1 for press and it starts , no holding in button , it may take a second or 2 on a frost morning Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #498664 15th Dec 2018 12:24am
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Brake then press for me.
My 1963 mini had a push button on the floor. Press and it might or might not start !
ps As did the school bus ! ! Forty years of progress. 1972-2012
Post #498872 16th Dec 2018 11:31pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Press the floor mounted starter button on an old mini too hard and it would just go through the floor......
Post #498954 17th Dec 2018 7:49pm
