Home > Technical (L322) > turbo solenoid with variable geometry alarm
Bluewater9118
France 2011 Range Rover Vogue SE TDV8 Nara Bronze
Hello everyone
I need your opinion informed I'm not too competent in mechanics.... Not even at all
On my 4.4 TDV8, driving on the highway at 130, I had the alert message 'Performance restricted' 'and in the process I lost all power.
At the bag the mechanic was able to read anomalies concerning:
- The particle filter
- The turbo solenoid with variable geometry.
He started me the procedure concerning the regeneration of the filter which after a while was displayed as successful.
Before going further my mechanic strongly advised me to do a descaling
We therefore made a descaling 1:30 in each air intake. At the exit, obviously all was well he had smoked black and I had recovered power. I did about 100 km on the sport position by riding a little bit of speed ... I tend to respect a little too much the limitations and the engine is at 1100 laps to 90 1300 to 110 and 1600/1800 to 130) .
Then again '' restricted performance ''.
This morning at startup the anomaly disappeared from the dashboard alone.
This afternoon… New restricted performances ....
Before committing myself to disassembling the turbos ... I would like your opinion.
Post #498046 9th Dec 2018 8:50pm
GGDR
Before you do anything your mechanic tells you, get yourself a code reader, ideally Gap IIDTool (an investment), get the actual errors and post them up here.
. Cheers, Greg
Post #498048 9th Dec 2018 9:26pm
GGDR
Oh and Bluewater9118 check your rubber inlet hoses. These feed into the 'donut' top of the engine intake. The hoses can crack and is often the cause of sudden restricted performance. They can crack underneath the clamps so you are best to remove and check. If they are fine, then this can be eliminated.
. Cheers, Greg
Post #498050 9th Dec 2018 9:47pm
Bluewater9118
I trust my mechanic, he will do all that is nescessaire before entering in big expenses.
This does not prevent to keep informed otherwise and to confront the opinions.
I see him this afternoon, I'll take a picture of the camera screen copy on the forum
Michel
Post #498067 10th Dec 2018 5:21am
GGDR
Ok - good you trust him.
As mentioned we need the error code numbers.
The 4.4 is very good, reliable however there are common issues. Please see here:
http://www.fullfatrr.com/forum/topic44115.html?highlight=4+4
I mentioned the intake hoses, this may help, sounds similar:
http://www.fullfatrr.com/forum/topic47735....ntake+hose
http://www.fullfatrr.com/gallery/albums/us...G_1518.JPG
Good luck.
. Cheers, Greg
Post #498069 10th Dec 2018 7:34am
Baltic Blue
It could possibly be The CSOV.
The change over valve for the turbo air supply. The early versions in the 2011 models were prone to sticking, and is a fairly easy repair. As Greg has said, you need the Fault codes.
Post #498071 10th Dec 2018 9:14am
nino_nino
Bluewater9118, here is the picture of the part Baltic Blue is talking about
Have your mechanic check for free movement of the valve.
Nino, 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #498074 10th Dec 2018 10:56am
GGDR
Where is that on the engine Nino?
Greg Cheers, Greg
Post #498082 10th Dec 2018 11:48am
GraemeS
Australia
The valve can be seen if you look down directly behind the radiator, middle right side when looking towards the engine. The different pivot for the vacuum chamber of the later version is quite easily identified.
Post #498083 10th Dec 2018 11:59am
nino_nino
here you go Greg,
2000 Disco. TD5
1975 series III
Post #498088 10th Dec 2018 12:51pm
Baltic Blue
By removing the plastic under engine tray it is much easier to access the valve to squirt a bit of penetrating oil and or, as I do before the winter months , apply a squirt of lithium grease to prevent corrosion by winter road salt.
Also note the modified valve does not have a nut on the top of the shaft.
Mike.
Clearer picture.
Post #498107 10th Dec 2018 5:09pm
Bluewater9118
J can now give you the errors codes:
P0401 - Recyclage des gaz d'echappement. Débit insuffisant detecté
P1247 - Pression de duralimentation du turbo compresseur basse
P0046 - Solenoide de contrôle de suralimentation du turbocompresseur/compresseur - Plage/perfomances du circuit
You know now all the reasons of my worry.
Michel
Post #498122 10th Dec 2018 6:15pm
GGDR
Google translated it:
P0401 - Exhaust gas recirculation. Insufficient flow detected
P1247 - Low turbocharger turbocharging pressure
P0046 - Turbocharger / Compressor Supercharging Control Solenoid - Range / Performance of the Circuit
. Cheers, Greg
Post #498127 10th Dec 2018 6:27pm
GGDR
From the Workshop manual:
 Cheers, Greg
Post #498129 10th Dec 2018 6:33pm
Baltic Blue
P 1247 seems to cover the CSOV stuck problem.
My guess would be clear that either by cleaning, oiling and seeing the actuator move, and the other Fault codes will then clear.
I was definitely told by the MD technician that it was a fairly common fault, caused by both the very small amount of travel and the build up of dirt/ corrosion from road salt.
Having said that , out of nearly 50 different owners providing data for my Fault Log, mine was the only one reported.
Post #498135 10th Dec 2018 7:17pm
